Home > Td5 > Discovery 2 , Aaaahhhhh!!! |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
Strange it's not the MAF. Classic symptoms of a failed one in my experience.
Will think about it and let you know if anything comes to mind. Good luck Andy |
13th Aug 2013 7:46pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Turbo hose delaminated or split ?
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
13th Aug 2013 7:52pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6105 |
Fuel pump? giving the correct pressure?
Have you connected the flow & return the right way around? so it's taking some time to purge the system? The pipes aren't too far from each other, so it's possible to do them the wrong way around (ask me how I know...) |
13th Aug 2013 7:56pm |
Phantom Member Since: 29 Jan 2013 Location: Isle of Wight Posts: 136 |
Don't think so, it's only for the first 10/20 seconds then fine, if it was a hose then I guess it would be all the time |
13th Aug 2013 9:21pm |
I'll double check the fuel pipe work tomorrow - hopefully it's that simple |
13th Aug 2013 9:23pm |
So....................its fixed! No faults on the Hawk Eye pro, checked everything again inc fuelling pipework and found nothing, brought a new OEM MAF, fitted it and fault gone! Yippee! The mad thing is I'd already tried two other ( used ) MAF sensors, both Siemens units and also run with the MAF disconnected, you learn something every day, thanks for all the pointers |
23rd Aug 2013 9:45am |
Millsy94 Member Since: 06 Jun 2013 Location: Gloucestershire Posts: 91 |
I have exactly the same in my 03 90, done it ever since i bought her and only recently was i informed that it wasn't a safety feature, likewise mine has been on the diagnostics and shows nothing wrong, after those first few seconds it drives like any other td5 i know of, just a if you are stall on a roundabout as its a steady crawl. having spoken to monster tuning they had the same with their eight wheeler and after replacing all sorts just replaced the ECU. ED
25th Aug 2013 4:00pm |
