Home > Puma (Tdci) > Steering Backlash
CapeLandy
South Africa
Steering Backlash
Do you think that a new steering box would have the backlash correctly set in the factory?
Reason I ask, when we collected the Landy the other day we saw the mechanic still sitting in the drivers side and wiggling the steering wheel from side to side. When I asked if all was ok he said "ready to collect sir"
I noticed today when I wiggle the steering there is an ever so slight knocking.
Could it be the pinch bolt on the steering link or the new box not properly set?
Any ideas how to search for the cause.
Big Cry
Post #20287 16th Dec 2009 7:42pm
AndrewS
I would take it back to the dealer.
Post #20297 16th Dec 2009 9:30pm
CapeLandy
South Africa
That's the end plan but with our dealer's it's best to be able to tell em exacltly what they need to fix.
Otherwise they just fob you off.
Post #20299 16th Dec 2009 10:00pm
CapeLandy
South Africa
Update
This morning I had a quick look and found there is vertical play in the lower steering column bush/bearing.
I can rattle the output shaft up and down to re-create the rattle.
Dosn't seem too seriouse a problem, but how did it all of a sudden start happening after fitting the new box?
Maybe the alignment is slightly not the same and the turning moment causes a slight lift on the column shaft.
I will have to have a good look Saturday.
Post #20315 17th Dec 2009 5:18am
Grockle
I wonder if a dealer will ever do a repair right first time 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #20325 17th Dec 2009 9:27am
CapeLandy
South Africa
Update
According to dealer it was a knock of the pinch bolt on the steering input against the fan cowl Embarassed
I Couldn't see inbetween all the plastic to notice that one.
Post #23741 7th Feb 2010 6:14am
