Home > Tdi > 300Tdi Oil. |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Always ran mine on 5w30 semi synthetic,Bought it at 103,000 kept it till 160,000 (well it went walkabout actually).Never had any issues. 2005 Td5 90 XS
Steve |
4th Aug 2013 4:56pm |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 |
I run my 300tdi on 10W40 Semi Synth (Fuchs Titan) and it seems fine as well as this is what is listed in the manual so should be ok. I think dropping to a 5W30 is ok too and may improve mpg etc.
4th Aug 2013 4:58pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
10W40 Part Synthetic.
Can go for the most expensive magnitech but its equally as happy on the cheap halfruads stuff. Before you change give it a run with a tin of engine flush in it till it’s warm, then drop the old oil while it’s still a bit warm (it will look like a mix of oil and coal dust which is normal) remember to replace the sump sealing washer and oil filter then refill with new oil. Up to you but I always add in a tin of Wynns oil treatment when I change as I feel it makes a difference to my engine's running but again, up to you. |
4th Aug 2013 5:04pm |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
I think Halfords are running an offer where all their oil is £10.
I recommend fitting a Drainplug to replace your sump plug, makes draining the oil so much easier. I got mine form Difflock... http://www.difflock.com/drainplug/ |
4th Aug 2013 5:09pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 |
My 300TDi was filled with Magnatec by the main dealer at the initial 1K mile service and I have used the same stuff every 6-months since.
They also stripped the drain-plug at said service so I fitted a Difflock Drainplug the next time (wasn't letting them near it again) and it has worked fine for all these years. ONE LIFE, GET IT! |
4th Aug 2013 6:23pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
Whatever costco are flogging! Big drum (20l or so) for the price of one bottle from usual shops. Think it's 10w40
Being a tdi, it will probably run on anything. |
5th Aug 2013 8:18am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2667 |
I just use 10w/40 or 15w/40 semi-synthetic - whatever I can get hold of cheapest at the time.
If you look in the handbook it actually tells you what fluids to put in and when |
5th Aug 2013 9:28am |
I popped into Halfords this morning as I needed a few bits and had a look at this oil. It is not their usual oil that is on sale, it is a 'special purchase' product. It is in 4L containers rather than their usual 5L and seems to be a cheap generic oil (petrol or diesel). The Halfords 10W40 turbo diesel specific oil is £17.99 for 5L.
I think I will stick with Fuchs Titan which I can get for about £18 for 5L from Opie as that is good quality stuff and not much more than Halfords. |
5th Aug 2013 11:05am |
drewster Member Since: 13 Jun 2011 Location: south coast brockenhurst Posts: 226 |
Try Morris c three 10/40 I find it very good
5th Aug 2013 3:19pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6618 |
There is a discount at Opie for Defender2 members 1988 90 Td5 NAS soft top
2015 D90 XS SW |
5th Aug 2013 3:39pm |
djgg Member Since: 22 Apr 2013 Location: Southport Posts: 22 |
Thank you all for your advice, one more question. I have 10ltrs of 15W40 multi purpose oil would this be ok to use? or do I need to buy some semi-synthetic oil?
David. |
5th Aug 2013 7:03pm |
Personally I would stick to a decent 10W40 rather than use up the stuff you already have, however tempting it is to save cash. However that is just me 'like things to be right' rather than a technical expert opinion.
5th Aug 2013 7:54pm |
I think your right, decent 10W40 it is then, but it was worth asking. David |
5th Aug 2013 8:06pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8113 |
Fuchs 10/40 Semi i run in my tgv's Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
5th Aug 2013 9:09pm |
