Home > Technical > Heated windscreen caused my breakdown? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6105 |
I can't believe that the wire isn't soldered into that pin in the plug.... even the proper factory crimped plugs don't grip that well, let alone one that's clearly been done by a pair of pliers
I'd go right through that screen wiring loom of it were me, and check (and solder) each connection. |
1st Aug 2013 1:54pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
It's worth investing in the correct crimp tool Warpig if you are going to do your own wiring and check the rating of the fuse you've installed.
There was a thread a while back that went into the various tools available and the pros and cons for each |
1st Aug 2013 1:58pm |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
Good point, ill look onto that, thanks
1st Aug 2013 2:02pm |
