![]() | Home > Wheels & Tyres > Issues with aluminium spacers? |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
I assume from this you were actually using a "spacer" which goes over the original studs like a big washer and you fit extended studs to compensate ? The "spacers" supplied for Land Rovers are normally not just a spacer, more of an adaptor - the adaptor bolts to the original studs and has it's own offset studs for the wheel to bolt to. This design means that there is no direct connection between the hub and the wheel and often some quite thin material left in the spacer/adaptor in places where it is milled away to allow the nuts holding it on to be below the level of the spacer. There is also no way of checking the tightness of the inner nuts without removing the wheel. http://www.yorkshireoffroadclub.net/ |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
You are correct, and that was my only concern as I already mentioned, that on the check list is checking the torque of the spacer nuts you have to remove the wheels to do so which is why it's recommended to put thread lock on them.
Spacers or Adapters, providing the "sandwich" affect of torqueing up the nuts is maintained, there should be no difference. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1979 ![]() ![]() ![]() |
ummm
![]() The main reason i want to fit them is to have a better turning circle especially for when towing my large caravan, they also look better and fill the arches that bit more, i like my boost alloys and don't really want to change them i have altered the stop nuts as much as possible but its still not quite right, ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17688 ![]() ![]() ![]() |
If you opt for good-quality aluminium alloy spacers from a reputable manufacturer (recommend Rakeway as mentioned above) you will have no problems.
Egghead Member Since: 25 Nov 2012 Location: Surrey Posts: 255 ![]() ![]() ![]() |
I use these: Terrafirma 30mm aluminium billet wheel spacers
Single billet aluminium and a brilliantly simple to use locating spigot. They are not the cheapest but with something like this I didn't want to compromise. Much more play in the turning circle (She can spin on her nose now) and the tyres still fit within the wheel arches so no problems with Mr Plod or MOT failures. Can't tell you if these are TUV approved - not applicable to me as the only scrutineering I ever face is how many beers the wife can find out I've had when I've been to the pub. Perhaps somebody can confirm TUV approval or not? Hope this helps. |
