Home > In Car Electronics > Puma X' over mounting
I have some X'overs to fit for each tweeter on my Puma. Where have you other chaps that have aftermarket tweeters fitted your's on Puma's?
I was thinking of mounting on velcro so they are removable if required & there isn't really anything else there can be zip tied to except other wires and that's just a mess and not a good idea IMO.
Ideas welcome. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #253903 27th Jul 2013 8:40am
theorangebandit
sticky pad tucked up into the dash sorted , in likely to need the removed but velcro pads are certainly going to do the job just the same
Post #253904 27th Jul 2013 8:44am
Good to hear. Just thought I would ask as inside info is the easiest and quickest. Wink I was mainly wanting to check there was a flat surface each side with enough room. No doubt there is. A few consumables to get on with and I can fit then. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #253926 27th Jul 2013 12:18pm
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
Anyone thought of using the seat boxes as sub enclosures?
Post #254013 27th Jul 2013 7:46pm
ZeDefender
This is sort of related... I use 3M vercro pads for most things these days. Just fitted the noise-reduction module inside the dash using them. Stuck like glue Thumbs Up
Results after it's wired in tomorrow Confused Tell someone you love them today because life is short.
Post #254018 27th Jul 2013 8:17pm
Ze - that was the sort of stuff I was thinking of using myself. Wink (Oh and good luck)
Shaun - Off Topic But if you want to discuss it try in the "Definitive Defender ICE Thread"
Personally I can't see it being any good the seat box would have to be air tight which is easier said than done. The front on the seat box is relatively small, an 8" may fit but the internal volume would be much to large. Vulnerable to damage by boots etc as well. The lid is too thin again air tight issues and seat clearance also an issue. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #254038 27th Jul 2013 9:37pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Would probably shake all the relays from their sockets! Rolling with laughter ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #254478 29th Jul 2013 8:47pm
^^ Rolling with laughter
Does it really take a Sub for that to happen anyway. Whistle TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #254491 29th Jul 2013 9:28pm
farmer giles
my 8" jl sub is located in the top of my cubby box, and the amp inside. the lid is screwed down and the insides filled with accoustic quilt. i have put a 8" sub in the rear face of the cubby box but i was never as happy with the sound.
the speaker has got a metal grille on the top to protect it from elbows and my 3 year old son walks over it without problems.
Thumbs Up
Post #254553 30th Jul 2013 8:29am
Black Tac is the answer better than velcro Thumbs Up
Post #254554 30th Jul 2013 8:35am
FG - If your Amp is sealed in how's it going too keep cool? Shocked Shocked Shocked Shocked
Ken - I shall look into that I've got some velcro at the moment so I'll try that but if it doesn't work out I'll try and get some of that.
Haven't had the chance to fit my new tweeters yet I'm too busy and more importantly the weather is very un-predictable. Unlike some of you my 90 has to stay outside. Sad TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #254598 30th Jul 2013 11:01am
