Home > Technical > Proximity alarms on a 2012 defender...help needed
adyb
Following the attempted theft of my one year old 90 van last week I need to up the defences a bit. I would like an alarm fitted that senses if someone is close by and starts to sound off before they attack it or tells them to back off....is tis possible on the defender and if so which is a good reliable and affective alarm to fit ?
Post #246880 26th Jun 2013 8:33am
What, like those annoying ones that used to shout "WARNING.... MOVE AWAY FROM THIS VEHICLE, IT IS ALARMED" whenever a fox wandered past...
Post #246884 26th Jun 2013 9:05am
adyb
Yep, one of those ! Seriously though, there are some that apparently go off when you are very close and not just walking within ten feet....hence the request to see if anyone has a food reliable one that works well ? If it had got one on it they wouldn't have managed to sever the main wiring loom !
Post #246900 26th Jun 2013 10:20am
Yeah, jesting aside, The last one of those talking alarms I ever saw was back in the 90's; i'm sure technology has moved on in leaps and bounds now so that proximity and false alarms are much better controlled.
Post #246910 26th Jun 2013 12:55pm
excossack
Not sure how difficult it would be, but would it be possible to put a micro-switch on the lock on the inside of the door to monitor someone pressing the button (i.e checking if a door is locked) and link this to a separate alarm. I guess this could also be linked up to the bonnet and also setup inside the door frames as well? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #246949 26th Jun 2013 3:04pm
Sockpuppet
How close is too close? What happens if you park it in a car park and someone gets out of their car next to you?
Post #246970 26th Jun 2013 4:10pm
Innuendomaster
I was thinking the same, something that chirps or whatever the expression is when someone is close....an audible warning.
Post #247002 26th Jun 2013 6:33pm
Sockpuppet
Like this?
Post #247003 26th Jun 2013 6:39pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Clifford still do a proximity alarm and cobra also.
Main problem is u will have 2 transponders unless you disable the lr unit
Post #247079 26th Jun 2013 9:43pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Sockpuppet wrote:
http://youtu.be/HFoUL_bIotw
Like this?
Rolling with laughter Rolling with laughter Rolling with laughter
Post #247105 27th Jun 2013 6:29am
Porny
Site Sponsor
Not always....
You can use an output from the 10AS to control the aftermarket alarm.
http://www.mobilecentre.co.uk/index.php?ma...0781b07cc5
This is exactly what this one does.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #247135 27th Jun 2013 8:33am
