Home > Td5 > Broken MAF i think
johnnyd
Broken MAF i think
Hi All
My new nanocom has exposed a possible MAF failure, I cleared the error, but it comes straight back, and the airflow on the nancom reads 0.0 with the engine in idle, does anyone know which fuse this is on a TD5 and also what the voltages should be on the MAF plug.......then i guess the next question is where is best for a new one, i read somewhere here that alive do cheaper uprated ones ?
Thanks
JD 2008 TDCi 2.4 XS CSW
Post #245289 21st Jun 2013 8:44am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
just get a genuine one, no need for uprated one. Our cars run OE MAF's with stg3 kits on them. Putting Dreams on Drives at JLR Solihull..
Post #245293 21st Jun 2013 8:50am
There's thread on here somewhere, where Porny posted the readings that a healthy MAF should show.
It's about 50 kg/hr at idle and up to 550~600kh/hr when on full chat.
With the engine off (but ign on) I think it should show about 4.5kg/hr
If it's showing 0 then it's dead. although remove the plug from it, give it a clean/spray in WD40 and re-insert. I thought I had a dead one, bought a replacement, and since unplugging the old one and re-fitting, it's been fine... so at least I've got a spare now!
Makes a huge difference to performance.
The nanocom can show this reading in real time... as in, when the engine is running. either on stand alone or if the nano is plugged into a laptop.
I prefer having it on a laptop, you can see so much more, and it's clearer, but if you're just after one particular reading, as in the MAF data, then stand alone is fine.
What version of nano have you got? mine is the old Mk.1 but works fine.
Post #245302 21st Jun 2013 9:10am
johnnyd
diesel_jim ......is it fused separately ?
Nanocom is the Newer Evolution from BBS direct with 10% forum discount, i don't think it has PC software anymore?
JD
edit
anyone know where i can get one in Bristol today, Im in Clifton ATM ? 2008 TDCi 2.4 XS CSW
Post #245303 21st Jun 2013 9:12am
Yes, it goes through fuse 37, 15amp
Which appears to be a "lone" fuse (i.e, not in the underseat or passenger fusebox) so looking at the wiring diagram, i'd suggest it was the fuse that's in the loom right next to the ECU/relays under the drivers seat.
It also feeds the EGR valve. it is powered from the main ignition relay (and cut-off by the inertia switch on the bulkhead)
Looking at the diagram; if the fuel pump is pumping, then there should be +12v to the +ve side of the fuse holder.
Post #245481 21st Jun 2013 10:08pm
ZeDefender
You can get MAF cleaner now - leaves no residue:
http://www.amazon.co.uk/Mass-Flow-Sensor-C...or+cleaner
I've cleaned several over the years and they usually come "back to life" Thumbs Up Tell someone you love them today because life is short.
Post #245483 21st Jun 2013 10:36pm
I cleaned mine out today with electrical contact cleaner, seems to be very similar stuff.
will check with the nanocom tomorrow as to whether i've killed it! Laughing Rolling Eyes
Post #245484 21st Jun 2013 10:40pm
johnnyd
OK i have volts on the contacts to the MAF so that looks good, i inspected the MAF closer, and all i can see is a piece of thin metal in there, i see no components or wire, should there be anything on the metal plate ?
Post #245498 22nd Jun 2013 7:46am
The metal is in a kind of "P" shape with a loop inside it. althugh different makes may look different.
Here's a random google image of one, you can see the sensor poking down:
[img]http://desmond.imageshack.us/Himg62/scaled.php?server=62&filename=photo1pse.jpg&res=landing[/img]
Post #245501 22nd Jun 2013 8:04am
johnnyd
Yeh i think the wire is missing from mine Sad That might be why its not working Wink
Is it worth me doing a remap with it broken do you think ? I will try to find a parts place in Chipnum this morning, but it may be difficult.
Post #245502 22nd Jun 2013 8:10am
You really want the engine in tip top condition before you try making it go faster.
Try Harfords. Or TH Whites parts dept are usually open until 13:00hrs.
Post #245509 22nd Jun 2013 8:35am
landy andy
Can't you borrow one from any other td5?
Andy
Post #245511 22nd Jun 2013 8:40am
johnnyd
I did try harfords, closed, didn't know about T H white.....and they have a patten one, not a landy one, for 44 quid, I know everyone says buy original, but they say these are OK any one heard of them?
Lol fixed spelling mistakes.......
I think it might be pattern....... Smile
Post #245513 22nd Jun 2013 8:47am
ZeDefender
My philosophy is always go original for "mystery components" (ones I can't understand) - that way if there's still a problem you can be fairly certain the fault lies elsewhere. Pattern parts always leave an element of doubt...
W.r.t. remapping, wait until the engine's working before you start confusing it more. Pete Bell indicated that remaps are "adaptive" to the engine parameters, which is another good reason to wait. Tell someone you love them today because life is short.
Post #245531 22nd Jun 2013 9:54am
johnnyd
I went for the Pattern, its guaranteed for 1 year at T H White Wink
And.......MAF now works and shows airflow on the Nanocom, and it drives better too Smile
Many Thanks all
Post #245538 22nd Jun 2013 10:53am
