Home > Td5 > Wading preperation
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
Wading preperation
Hi all, im looking at preparing my 2003 90 for wading i'm aware of the obvious, air intake and breathers and electronics although after changing the injector loom recently i am concerned about a plastic cap on the cylinder head, there is a black plastic cap inline with the camshaft on the front face of the head, its not a tight fit neither does it have any form of seal?? surly this would allow water ingress?? any help/ advice gratefull. ive not had her long so still learning, treat me like the idiot i am cheers Ed
Post #243672 14th Jun 2013 8:22pm
That camshaft cap is fine.... if oil doesn't come out then water won't come in (and it's under a bit of pressure from inside the engine.
Usual suspects are: wading plug in clutch bellhousing, ECU under the drivers seat, throttle pedal (Can revert to "tickover" only if it gets too wet.
Post #243678 14th Jun 2013 8:41pm
Millsy94
Ah cheers ok i saw it and wondered, wading plug? is this in a holder somewhere as on older defenders or have i got to locate/ find a bolt? Ed
Post #243689 14th Jun 2013 9:00pm
There's not a holder for it, like the older models had. so it'll either be fitted or in the cubby box/tool roll.
Post #243695 14th Jun 2013 9:09pm
Millsy94
OK thanks
Post #243700 14th Jun 2013 9:20pm
