Home > In Car Electronics > Carling Contora II switches
excossack
Are the standard on/off switches OK for Rear fog/hazards/demister? (Rear fog and demister I guess are OK) but not sure on Hazards? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #243645 14th Jun 2013 6:54pm
GUM97
I tried to hook the rear fog up to one on mine, and lets say it wasn't easy... Problem being is that the standard rear fog switch on my 300Tdi (and I assume the early Td5s) , is a biased off switch (it's spring loaded into the off position). When set up on the carling switch, there effectively became 2 on positions! (Push once to turn on, then push again and it stayed on, then push again and it went off.) I couldn't get my head around it, so got the auto spark in who changed the relay to a standard relay, and all is well now Very Happy
Sorry if that's a bit hard to follow, but it's not easy to write it really! Thumbs Up An engine to TDi for!
Post #243761 15th Jun 2013 8:09am
excossack
I noticed it was spring loaded but....mmm... I was hoping it was a standard on/off switch....Time to look at the wiring diagram. 1999 Defender TD5 110
Regards
John M0VAZ
Post #243771 15th Jun 2013 8:44am
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
I'm pretty sure that a standard on/off switch will be fine for your rear fog and demister. I don't know if the timer on the demister is on the switch or on the unit, if its on the unit them a mom/off switch would be better. As far as the hazard switch goes you need a special switch. All of these are available at www.mudstuff.co.uk.
Regards,
Mark
Post #243784 15th Jun 2013 10:53am
excossack
I did'nt realise the demister was on a timer. I thought it was on until you turned it off.? 1999 Defender TD5 110
Regards
John M0VAZ
Post #243874 15th Jun 2013 4:56pm
