Home > Maintenance & Modifications > Differentials |
lockers are great...if used correctly. you can still *uck up with them.
ATB are there all the time passively working with the TC and ABS to help you on your way. uprated shafts and cv's may be required using lockers as you could have a situation where the drive is all through one wheel and pop goes the drive shaft |
26th May 2013 9:15am |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
Yes, a locking diff that you can control is the best option for off road use. http://www.yorkshireoffroadclub.net/ |
So it's piffle when I say it but presumably makes perfect sense when you say it ? http://www.yorkshireoffroadclub.net/ |
26th May 2013 10:31am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17469 |
Far from it, but I felt you were a bit harsh on the ATBs. Thousands of people over the years have used torque biasing diffs to great effect off-road and they are a serious contender. That's all I was trying to say.
27th May 2013 8:07am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8094 |
an axle locker you lock you lock yourself is the ideal for off road use but you need to know when and why you would put them in and take them out.
Some prefer the ATB or similar as its an easier install and you dont have to do anything to operate them, but as ^^ they are not a true locker. the Ashcroft locker was a spin off of the force 9 locker design i believe. its bloody good. has a better engagement system (longer engagement pin over a ARB), better diff mounting system and disengages much quicker than an ARB. i have ARB F & B on a truck and Ashcroft lockers (Force9) on another. when the ARBs goes tits they will be replaced with Ashcroft units. Personally i would not run an axle locker without upgrading shafts and CVs Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
27th May 2013 6:54pm |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
Great info,guys! Much appreciated!
27th May 2013 7:25pm |
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 |
For me the ATBs work very well. I think the terrain that really needs manual controlled lockers is nothing I conquer very often. It depends on how severe you "off-road", doesn´t it.
An advantage the ATBs offer over the manual lockers is that you will still be able to steer the vehicle to where you want to go when they´re active. And, of course, I needn´t think about turning them on or off. Still - nothing for the rock crawler. |
27th May 2013 7:50pm |
pjh Member Since: 22 Nov 2010 Location: West Yorkshire Posts: 126 |
Blackwolf, I agree with all your comments on the ATB, but why would you not describe it as an LSD - I run a Quaife ATB in a Ctaerham and that's exactly the role that I thought it performed? Interesting thread. Peter Defender 11MY USW |
28th May 2013 1:26pm |
It was always my understanding that an LSD and an ATB were different albeit similar devices, with the LSD using clutches to limit the difference in rotational speed across the axle (ie based on relative speed not power), and the ATB using helical differential gears and internal friction to achieve a mechanically more sophisticated power split. Prior to writing this post, however, I did some reading and it is actually considered that an ATB is a type of LSD, so whilst it is true to say that all ATBs are LSDs, there are several other types of LSD. It seems however that my original understanding is essentially correct. A torque biasing diff directs its power proportionally to the available traction, whereas a generic LSD may use a preset power distribution or operate by limiting the allowed speed difference. If you look up "limited slip differential" on Wikipedia (link http://en.wikipedia.org/wiki/Limited_slip_differential) there's quite a good explanation of different types. |
28th May 2013 5:10pm |
