Home > Maintenance & Modifications > heated mirrors
Juddy
Australia 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
heated mirrors
Are the 24 volt mirrors that are for sale on ebay etc, suited to a 12v land rover, ie can they be used with some modification.
And how are they fitted. 2010 Defender 130 HCPU
1991 110 RFSV PERENTIE
www.landybitz.com.au
Post #238499 25th May 2013 9:04am
VeeTee
Netherlands
Why not buy a 12V kit?
http://www.ebay.co.uk/bhp/land-rover-defen...5573.m2388 Cheers, Vincent
MySite
Post #238507 25th May 2013 9:43am
Juddy
Well good thought, but I have 24v Wolf mirrors going spare. 2010 Defender 130 HCPU
Post #238512 25th May 2013 9:53am
The heated bit is usually only a stick on element behind the glass, so you could remove the glass, take the 24v element out and fit 12v ones?
Although.... i suppose if you just stuck 12v through a 24v element, it would just only heat up half as hot as it should. might still demist the glass, just twice as slow.
Post #238515 25th May 2013 9:55am
Juddy
Good point Jim
Thank you mate... 2010 Defender 130 HCPU
Post #238516 25th May 2013 9:56am
VeeTee
Netherlands
May be you can modify the heating element, i.e. like splitting the element in 2 parts (make a isolated part in the middle) and then supply the feed in pararallel. This way you have 12 V over the half of an element, which would have the same effect as 24 V over one whole element. Cheers, Vincent
MySite
Post #238521 25th May 2013 10:14am
CarlW
Scotland 2011 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Half Volts will result in 1/4 of the power not 1/2 the power - might still work but will be far less effective
Carl MY11 110 XS Station Wagon in Stornoway
Post #238610 25th May 2013 9:41pm
VeeTee
Netherlands
Carl
Question
This way you put the same volts across each half element - which is effective the same as putting double volts across one whole element.
... Or do I miss something? Shocked Cheers, Vincent
MySite
Post #238625 25th May 2013 11:01pm
CarlW
No if you can split the element into two equal sectiona and apply 12v across each half you;ll be back to full power
Post #238804 26th May 2013 8:11pm
VeeTee
Netherlands
Carl
Thats exactly what I said Question Rolling Eyes Evil or Very Mad Cheers, Vincent
MySite
Post #238807 26th May 2013 8:17pm
