Home > Technical > So there's actually nothing wrong with this?
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
This is the left hand rear lower shock mount on the Puma. The right is identically put together. These are as delivered and have not been touched.
Can you spot anything amiss?
 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #17988 8th Nov 2009 8:59am
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Your washer is the wrong way round and looks like rubber gromet is missing unless it's very compressed. Puma 110 SW
90 V8 SOFT TOP
Post #17989 8th Nov 2009 9:50am
dm_td5
The rubber is there above the washer. I've since learned on ALRO that it is actually correct for OEM factory fit.
Go figure! I would have thought that the washer would cup the rubber like on any other shock. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #17990 8th Nov 2009 10:04am
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
No, the washer should always be this way round.
If it cups the bush it doesn't allow for flex in the shock absorber as it extends and compresses, remember it is unlikely to stay straight as it moves so some lateral movement must be allowed for.
Every shock I have ever changed, had the washers this way round, so I have always fitted the new ones the same way, never had any problems. MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #17996 8th Nov 2009 11:58am
LESVOSD110
I just had a look at mine and it's the same,but the front is the other way round.Why differnt on the front then.Looks like somebody made a change and thats how it is now.
My v8 has 320000km (With shock changes) so why do it different.Just a Land Rover thing I suppose and thats why we Bow down landies.
Cheers Puma 110 SW
90 V8 SOFT TOP
Post #17997 8th Nov 2009 12:02pm
jst
i thought the rears were that way around as the td5s etc had a metal casing on the bottom of the axle to shock mount to locate the bush. if the washer was the other way around it would hit the outside edges on the casing before compressing the bush.
the rear tops are definately that way around too but i believe the fronts are the dome out top and bottom. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #18106 10th Nov 2009 8:37pm
Grockle
Re: So there's actually nothing wrong with this?
yes,it's filthy Derek Laughing 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #18171 11th Nov 2009 5:55pm
