Home > In Car Electronics > Interference on stereo
GSLRO
United Kingdom 2002 Defender 110 Td5 CSW Chawton White
Stereo is a Clarion DB568 RUSB.
I can play music through my phone (Sony Experia Arc) via a the stereo AUX socket no problems, but as soon as the phone is connected to the 12V socket to charge you can hear the whistle / whine of the engine / turbo.
Is there a cheap easy fix?
George Bow down
Post #235268 13th May 2013 7:37pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
If your mobe uses a "standard" micro USB charging lead, try to get one with a ferrite core molded onto one end..
Like THIS ....... ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #235308 13th May 2013 10:13pm
When you say connected to the HU Aux do you mean via an audio jack? If so make sure it's secure. Sounds simple I know but sometimes if it's not fully inserted and secure it can cause a little bit of noise issues. My home hi-fi will do if not connected perfectly. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #235344 14th May 2013 10:08am
GSLRO
Cabled tied in so secure as a secure thing. Not the best quality leads I guess but will try the ferrite core lead approach. Seen some on fleabay for a couple of quid so worth a punt!
Thanks folk! Thumbs Up
Post #235506 14th May 2013 6:29pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Any luck GSLRO. Did the ferrite core work? LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #236857 19th May 2013 3:09pm
skyeplumb
Scotland 2007 Defender 110 Puma 2.4 USW Rimini Red
Cured mine with a ground loop isolator from maplins, bit bulky but fitted in behind the dash. Series IIa Lightweight - Long Gone
Discovery 1 300Tdi - Sold
Defender 110 XS 07MY Utility
Post #237605 21st May 2013 8:55pm
