Page 589 of 1377 <123 ... 588589590 ... 137513761377>
kjmeijer
Netherlands 2016 Defender 110 Other SW Galway Green
I fitted chequer plate sills to my 130:
 2021 Defender 110 D300 HSE
Post #278010 30th Oct 2013 12:25pm
AlexPuma42
not technically today but last night had to pull a motor out of a very boggy field - tyres disappeared into the mud and was drastically trying to get grip - the motor i was pulling out had flat tyres so that didn't help but the land pulled through after engaging low ratio and diff locks, the land i spent 5 hours cleaning on sunday is now caked in mud the joys of land rover ownership 110 Hard Top - Izmir Blue
Post #278025 30th Oct 2013 1:47pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Still trying to sort out my abs. ECUtesting.com declared it unrepairable so got another one from equicar. Should be here tomorrow and fitted at the weekend. Can't wat to be free of those three lights Rolling Eyes William
Post #278027 30th Oct 2013 2:08pm
JWL
Got halfway across an awkward road junction this morning when there was a dull thud and no forward motion. Quick engagement of the diff-lock and went on to where I was going, only another mile up the road. I was thinking half shaft, CV joint but luckily it was the teeth stripped out of a rear drive flange. I'd replaced two on the back about 6months ago and it was one of those, bit of a Censored really but it's not given me much confidence in Bearmach, still dug out a worn one I took off but chucked in the back "just in case", slapped that on and away we went. I'm still not convinced on getting a Heavy Duty set, I'm happier changing a drive flange than a half shaft or worse still something deeper in the drive train.
Post #278029 30th Oct 2013 2:22pm
william8
Lucky, when that happened to me it was the front diff Embarassed William
Post #278032 30th Oct 2013 2:31pm
jimbob7
Good luck,let us know how it goes.
Back O/T.
Dinotroled the INSIDE of the battery box,coz I were bored and had nowt to do and it were starting to get a bit scabby.
Post #278033 30th Oct 2013 2:33pm
jimbob7
I fitted the HD jobbies a while back, I better be careful about those Br*tpart halfshafts I just fitted,eek.Plan to get Ashcrofts next year when funds allow.
Post #278034 30th Oct 2013 2:39pm
mk1collector
Fitted new steering box arm and ball joint and the weather actually stayed dry for me Mr. Green only took ten mins Thumbs Up
Post #278045 30th Oct 2013 3:49pm
Vizsla
Fitted my new bonnet security hinges today (thanks again Brendan)
Very pleased with the finish on the hinges and they fitted without any need to adapt the bearings as they fitted in the curl hinge without any problems. Additional Silkaflex and ball bearings and now far more secure than the original fittings.
Yesterday I fitted the new locking cubby box (thanks Matt). Very pleased with the finish on this too and its much more substantial than the old OEM box Thumbs Up
Great service from both 4x4 Overlander and FCX respectively Thumbs Up Thumbs Up
Post #278048 30th Oct 2013 4:12pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
Took it for a wash to the local UN cleaning station, normally a great job, but today just okay.....so washed myself again when I got home, then decided as I was bored I'd polish it as well. _______________________________
Puma Defender 90
Post #278060 30th Oct 2013 5:17pm
foxkilla
United Kingdom 2008 Defender 110 Puma 2.4 USW Auto Tonga Green
Decided it was time for the winter wheels Very Happy
 DEFENDER XS UTILTY 110 AUTO
ONLY ACCURATE GUNS ARE INTERESTING
Post #278261 31st Oct 2013 12:04pm
Thank you for the business vizsla, I'm glad you were pleased Bow down
Happy to give you £40 for your old cubby if it is a genuine XS one
Post #278276 31st Oct 2013 1:23pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Fitted Crystals and OSRAM Nightbreaker Ultimate bulbs .. just waiting for it to get dark Very Happy
Ordered Remap interface from BAS Auto Services. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #278580 1st Nov 2013 2:44pm
excossack
Notice my clutch Master Cylinder is leaking...again. So ordered a genuine LR one. £72 + VAT! now I need a dry weekend to do the job in-between, decorating, testing radios for the rally, dialling into works servers to make sure all is well and removing floor boards. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #278690 1st Nov 2013 9:07pm
Etched my LED headlights using the ISR etching kit and fitted A bar to 110
Post #278722 2nd Nov 2013 7:00am
