Home > My Defender > What Did You Do In Your Defender Today |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
Which brand/supplier of removable boss did you buy Alex? |
11th Mar 2013 4:53pm |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 |
I got it from CSK Landrovers here on the forum.
Just makes me sleep a little more soundly at night knowing it has another layer of protection. |
11th Mar 2013 5:25pm |
Spruce Pirate Member Since: 08 Feb 2013 Location: Stirlingshire Posts: 124 |
Got an MOT! First time of asking and no advisories - happy days! Dirty Deeds - Done Dirt Cheap
11th Mar 2013 8:06pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
11th Mar 2013 8:24pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6113 |
Made some nice rock sliders for the project90, and got a coat of red oxide on them too.
11th Mar 2013 8:34pm |
ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277 |
Received my new injector loom/harness, stripped it down and ATV glued every single hole, cavity i could find shut..
11th Mar 2013 9:19pm |
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 |
My other half heroically spent the day in the freezing cold finishing off the next round of electrical / electronic re-jigging in my 90.
Tomorrow, if we are brave enough, we will start on taking the back end of the cage off to drill holes for the bolts we never got time to put in last summer. While the back cage is off we will also be swopping out the old rattling rear sliding windows for some brand new Masai ones that arrived last week. Also ordered some window guards today, not sure when they will arrive, but another item on the list for the Australia trip! Our blog - http://landytravels.com/ Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
12th Mar 2013 1:03am |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 |
Got any pics Jim? |
12th Mar 2013 8:31am |
Cracka Member Since: 08 Dec 2012 Location: New South Wales, Australia Posts: 129 |
Click image to enlarge New wheel..... Last edited by Cracka on 12th Mar 2013 11:15am. Edited 1 time in total |
12th Mar 2013 10:38am |
I like that alot looks great quality CSK Automotive
12th Mar 2013 11:00am |
G'day Killer, thanks mate. I got the your lovely centre cap in the mail today, great work on that but sadly I'm having a bit of trouble. It appears my wheel centre hole is smaller that a Momo, only 46mm across, not sure what a Momo is, which is going to cut out the edges of the oval I am hoping that it will fit under the ring without having to reduce the diameter of the new cap.
I'm assuming it is self adhesive by the white backing paper? Do you normally just take off the dress ring (around the horn button) and then stick it to the horn button and replace the ring over the top? By the way the wheel is an Australian built job, SAAS brand. I fitted it to a Momo boss, part No. 5613 but I did have to reduce the small collar at the top of the column shroud by about 3mm. The wheel has only moved out about 12mm from the standard wheel position which I was happy about. Last edited by Cracka on 12th Mar 2013 11:45am. Edited 1 time in total |
12th Mar 2013 11:12am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5881 |
Replaced the sidelight and rear number plate bulbs with LED ones. 1999 Defender TD5 110
12th Mar 2013 11:40am |
Took a couple this morning actually when I gave them another coat of redlead. Will upload them later. But in short, I used some 80x40x3mm box. Piece of round tube welded on to fit inside the tubular outrigger on the 90, and a couple of bits of plate to mount onto the bulkhead outrigger. |
12th Mar 2013 1:23pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
Still fitting dynamat only another 22 sheets to go then the closed cell foam
12th Mar 2013 3:54pm |
