Home > My Defender > What Did You Do In Your Defender Today |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
today I fitted these
Click image to enlarge and this...the old one was not working well - poor radio signal, volume buttons stop working - so found this one for 80€, no CD though, but with bluetooth, USB, Aux In, Ipod conect, etc.... Click image to enlarge and these, finally, after one year and half stored in a shelf...with a help of a friend who welds and works on metal for a living.... Click image to enlarge Click image to enlarge and fitted side hinges to the tailgate....now just have to get the tailgate painted....the hinges will be black... Click image to enlarge Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. Last edited by lrmaniac on 4th Jan 2013 9:58pm. Edited 1 time in total |
4th Jan 2013 8:26pm |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2382 |
Took my winch comp 90 for its mot which failed on x2 rear wheel bearings and rear propshaft. Deep joy! More hub bearing work for me!!!!
110 having its wheel bearing replaced yesterday BBCode Full Size 90 awaiting its impending doom of mot BBCode Full Size BBCode Full Size 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
4th Jan 2013 8:43pm |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Think I should have replaced 'sensible' with 'boring' ha Having said that the Astra is an absolute steal (not literally!) and the Defender was a bit overpriced... |
4th Jan 2013 10:18pm |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 |
Took a little drive out with my 2 lads yesterday and ended up doing a couple of lanes, my first of 2013.
Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
5th Jan 2013 10:45am |
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 |
Well today I thought I'd install the new head unit, speakers etc, however thought I'd best finish the sound proofing of the cab . Took everything out and cut to size, then tidied the odd cable in the battery box. Found some non Land Rover cables routed into the back of the Head unit, exactly the ones where I will connect the new temperature gauge:!: Followed them back to a strange black box, rely type configuration mounted on a black plastic panel fitted on side nearest the door also noted small cable runs out and up passenger door frame No idea what it is or does
Anyway ran out of time so seats, runners all sat in the garage with speakers etc. Still always tomorrow _______________________________ Puma Defender 90 |
5th Jan 2013 5:41pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
You have PM re the black box
Stripped my interior today and gave a good clean, blacked the dash, door cards, floor covering and rear liner, vacuumed and generally tidied up inside. Started to lay out all the kit for the Norway trip ready for packing into the storage boxes. Will be cleaning outside next week starting with all the wheels off to remove the Salisbury glue. Only 17 days to the Northern Lights 2007 TD5 90 Hard Top |
5th Jan 2013 6:49pm |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
Fitted patriot rear cage to double cab
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Think I'm going to spray rear door black Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
5th Jan 2013 7:15pm |
ClaireWright Member Since: 12 Oct 2012 Location: Warwickshire Posts: 609 |
Drove my daughter home down m40
5th Jan 2013 7:20pm |
mfspannerman Member Since: 18 Nov 2012 Location: Suffolk Posts: 36 |
went shooting got defender covered in mud then washed defender and fitted new wipac cyrstal headlights what an improvement!! Make tracks and get moving!!
PUTTING FOOD ON YOUR PLATE IS WORTH THE WAIT! PLEASE BE PATIENT! |
5th Jan 2013 9:08pm |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 367 |
Re-arranged the bracket holding my Safari-Equip spare wheel carrier to the tub - it had started to stretch the rivet holes holding the corner rub capping causing movement and a geiger-counter-style ticking that was driving me potty. A couple of extra rivets and an extra bolt through the capping finally firmed things up...
After that I sorted out the central locking actuator on the offside rear door that had been tetchy lately. After much messing about realised the little bellows on the actuator was catching on the push rod and making it stick a bit. Whilst I was in there found quite a bit of rust so I thoroughly drenched the door frame in Dinitrol 3125. Then, if that wasn't enough, I started the job of soundproofing the rear after taking out the sodden rear carpet last week. Got the loadbay floor done but now need to do the seat boxes. Another day - or two... Nice having a decent day to crack on with stuff... Dave Green Goddess - 1998 Defender 110 300tdi |
5th Jan 2013 10:09pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5831 |
Changed the wheel on the wifes Focus as the tyre had a screw through the shoulder of the tyre, luckily I had one of the original tyres to hand that was going to be used as a spare when I get 2nd hand rim.
So, a tyre that was 3 months old is now binned! and tip run 4 bags of rubbish and one builders bucket of Lilly trimmings. All in the 110. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
5th Jan 2013 11:19pm |
dhopable Member Since: 31 Dec 2012 Location: Peterborough Posts: 47 |
Got some new tyres for its christmas present... (havent figured out if its a he or she yet)
http://sphotos-e.ak.fbcdn.net/hphotos-ak-a...3320_n.jpg And planning on fitting the Mud bulkhead removal bar and rails when they arrive this coming week.. My knees cant wait for the legroom!! Oh and got some osram nightbreaker bulbs coming after reading the '5 best upgrades' post!! |
5th Jan 2013 11:52pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8580 |
A complete novel day today in the UK for me!
Have NOT driven a Defender or touch one. Feels completely strange to me. Brendan |
6th Jan 2013 12:16am |
The carpets have come out to start the mammoth task is stopping water coming in and prepping for dynamat. It'll be a slow few weeks job though trying to fit the work in around other chores
6th Jan 2013 12:43am |
