Home > My Defender > What Did You Do In Your Defender Today |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 |
Roolites or Lightforce (based around the same design I believe) are probably best bang for your buck, the 170's should fill out the bar well enough without being too large & sticking proud of the bumper. You can go pretty big with the lamps, but personally I prefer them smaller and more powerful. Check out these 170's http://www.lightforce.com/products/170-striker if you go for the HID's you should get plenty of light output. I manufactured some small extension brackets for my Hella's so that they are dropped in line with the factory headlights. Being pretty much the same diameter, they line up pretty well. I'll see if I can find a photo for you
Alex 110 Tdci Double Cab |
19th Jan 2012 4:05pm |
You can sort of make out the brackets here :
Click image to enlarge _DSC3474-2 by .:ay4alex:., on Flickr Before being powder coated : Click image to enlarge IMG_0469 by .:ay4alex:., on Flickr 110 Tdci Double Cab |
19th Jan 2012 4:16pm |
xatzhs Member Since: 12 Dec 2010 Location: Northumberland & Down South Posts: 258 |
I got my Roo Lights on the aircon grill and nudge bar... I think they may possibly have a little bit of a large diameter, but they do make a great difference and haven't had any problems with them yet! Uploaded with ImageShack.us |
19th Jan 2012 6:33pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Is that a First Four steering guard? Lights look right size to me
19th Jan 2012 7:12pm |
Knot Yet Member Since: 01 Mar 2010 Location: West Sussex Posts: 197 |
Am also a Roo fan, work well and make a good bit of difference Defender 110 Puma Utility XS
20th Jan 2012 6:45am |
20th Jan 2012 7:39am |
ngarigo Member Since: 24 Nov 2011 Location: Alice Springs N.T. Posts: 81 |
fitted bumperettes
34 by Defender 90, on Flickr 33 by Defender 90, on Flickr Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming... 'Wow...! What a ride! MY11 90 |
20th Jan 2012 10:53am |
They look great, love your truck. Are they Equipe 4x4? 110 Tdci Double Cab
20th Jan 2012 11:17am |
thanks mate yep... sure are... had to lose the rear mud flaps though... ahh well Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming... 'Wow...! What a ride! MY11 90 |
20th Jan 2012 11:41am |
Just curious but, when I was fiddling about putting the bumperettes on the back of my motor I came across a piece of steel bar about 8mm thick by 13mm wide that was fixed inside the X member. This bar was fixed inside and seemed to follow the lower angle of the box section. It is biased to the front of the car leaving a gap of 13mm from the outside face and caused me a fair amount of difficulty to poke a bolt through the X member from the inside. This bar is on both sides and for the life of me I can't work out what it's there for, apart from to off interfeering, fiddling Defender owners
20th Jan 2012 12:01pm |
hmmm... i don't know jwl... it was a very straight forward fitting for me this arvo with mine... not sure what you've got there...? Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
20th Jan 2012 12:16pm |
Going nuts doing my tax return so had a break under the bonnet with a cuppa and a cloth - Zagtastic
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
20th Jan 2012 1:16pm |
geez... have you ever turned that engine on...? Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
20th Jan 2012 1:21pm |
Next job to clean the inside of the engine |
20th Jan 2012 1:26pm |
