Page 224 of 1378 <123 ... 223224225 ... 137613771378>
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Roolites or Lightforce (based around the same design I believe) are probably best bang for your buck, the 170's should fill out the bar well enough without being too large & sticking proud of the bumper. You can go pretty big with the lamps, but personally I prefer them smaller and more powerful. Check out these 170's http://www.lightforce.com/products/170-striker if you go for the HID's you should get plenty of light output. I manufactured some small extension brackets for my Hella's so that they are dropped in line with the factory headlights. Being pretty much the same diameter, they line up pretty well. I'll see if I can find a photo for you Thumbs Up
Alex 110 Tdci Double Cab
Post #116792 19th Jan 2012 4:05pm
ay4alex
You can sort of make out the brackets here :
_DSC3474-2 by .:ay4alex:., on Flickr
Before being powder coated :
IMG_0469 by .:ay4alex:., on Flickr 110 Tdci Double Cab
Post #116796 19th Jan 2012 4:16pm
xatzhs
westfield106 wrote:
Dont want cheap ones but not spending hundreds on something
That only get used every now & then !!! Like the look of the
Roolites.
I got my Roo Lights on the aircon grill and nudge bar... I think they may possibly have a little bit of a large diameter, but they do make a great difference and haven't had any problems with them yet!
Uploaded with ImageShack.us
Post #116828 19th Jan 2012 6:33pm
Zagato
Is that a First Four steering guard? Lights look right size to me Thumbs Up
Post #116853 19th Jan 2012 7:12pm
xatzhs
On mine?
If yes: No it's a steering guard from Cheviot 4x4... Got a little bomb shape cut out of the middle hole I thought it looked quite cool!
If no: I apologise for stealing that question.
Post #116929 19th Jan 2012 11:18pm
Knot Yet
England 2012 Defender 110 Puma 2.2 USW Orkney Grey
Am also a Roo fan, work well and make a good bit of difference Thumbs Up Defender 110 Puma Utility XS
Post #116939 20th Jan 2012 6:45am
Zagato
xatzhs wrote:
It's a steering guard from Cheviot 4x4... Got a little bomb shape cut out of the middle hole I thought it looked quite cool!
Thumbs Up
Post #116947 20th Jan 2012 7:39am
ngarigo
Ireland 2011 Defender 90 Puma 2.4 SW Santorini Black
fitted bumperettes Thumbs Up
34 by Defender 90, on Flickr
33 by Defender 90, on Flickr Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
'Wow...! What a ride!
MY11 90
Post #116997 20th Jan 2012 10:53am
ay4alex
They look great, love your truck. Are they Equipe 4x4? 110 Tdci Double Cab
Post #117004 20th Jan 2012 11:17am
ngarigo
thanks mate Very Happy
yep... sure are... had to lose the rear mud flaps though... ahh well Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
MY11 90
Post #117010 20th Jan 2012 11:41am
JWL
Just curious but, when I was fiddling about putting the bumperettes on the back of my motor I came across a piece of steel bar about 8mm thick by 13mm wide that was fixed inside the X member. This bar was fixed inside and seemed to follow the lower angle of the box section. It is biased to the front of the car leaving a gap of 13mm from the outside face and caused me a fair amount of difficulty to poke a bolt through the X member from the inside. This bar is on both sides and for the life of me I can't work out what it's there for, apart from to Censored off interfeering, fiddling Defender owners
Post #117012 20th Jan 2012 12:01pm
ngarigo
hmmm... i don't know jwl... it was a very straight forward fitting for me this arvo with mine... not sure what you've got there...? Whistle Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
MY11 90
Post #117016 20th Jan 2012 12:16pm
Zagato
Going nuts doing my tax return so had a break under the bonnet with a cuppa and a cloth - Zagtastic Very Happy
Post #117030 20th Jan 2012 1:16pm
ngarigo
geez... have you ever turned that engine on...? Whistle Very Happy Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
MY11 90
Post #117031 20th Jan 2012 1:21pm
Zagato
Laughing Next job to clean the inside of the engine Shocked Laughing
Post #117036 20th Jan 2012 1:26pm
