Page 1122 of 1382 <123 ... 112111221123 ... 138013811382>
Harry.O
Nice work AJC, that series 1 is gorgeous Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #716830 9th Jul 2018 6:46am
Harry.O
double post 2005 Td5 110 Hardtop
Post #716831 9th Jul 2018 6:47am
Ghound
United Kingdom 1999 Defender 110 Td5 SW Alaska White
I fitted a Mudstuff rear card to the HD galved door on my 110TD5, a very nice item, gives it a factory look.
Post #716869 9th Jul 2018 10:47am
Just drove it, had to go an get some hay bales in the trailer. Not usually at this time of year. Rolling Eyes
Liking the new wax I've used on my 90, to the eye it appears a darker shade than the #26 Yellow I have been using for a while.
Been thinking about getting parts Galvanized, but more a winter thing as too busy.
What do most of you expect to pay for blasting and Galvanizing? Obviously depends on how many parts but any guides? KEEP CALM AND Drill ON
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #717190 11th Jul 2018 5:46pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Put the Mantec roof bars back on ready for transporting the missus to vend at a yarn show.
Considering they are under 12 months old and spend nearly all the time in the shed the finish is starting to look flakey in places. Rolling Eyes 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #717219 11th Jul 2018 7:30pm
You put your wife on the roof bars to transport her? ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ‘๐Ÿป KEEP CALM AND Drill ON
Post #717235 11th Jul 2018 9:34pm
Rosco
Some days it would be preferable, but her flailing in protest would cause too much damage to the roof Laughing 2007 - Stornoway Grey 90 XS SW - Gone
Post #717263 12th Jul 2018 7:19am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Blasting is cheap, Iโ€™ve just had an 80โ€ bulkhead and a few other small parts done for ยฃ50,
Galvanising will be expensive if you have only a small quantity of parts, and some places wonโ€™t do one off/small items.
Our local (Wessex galvanisers) were good, ยฃ130 for a Series chassis, and ยฃ120 for all the cappings, screen frame etc,
Now they charge ยฃ10 per item on small parts, as they got fed up with people wanting an absolutely flawless Finnish,
If you can? Your best bet is to find someone who also needs some done, and double up on the quantity. Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #717275 12th Jul 2018 9:27am
JOW240725
Took the scenic route home...
 James
Instagram @suffolk_rovers
Post #717297 12th Jul 2018 1:29pm
Ghound
I made up a window vent, it was a rush job as i need it for tomorrow. It slips into the window channel, then the window slides into one end of the vent and the window catch keeps it closed.
It's a bit bigger than i need, so I'll knock up a nicer set for the 110 next week.
Post #717309 12th Jul 2018 2:42pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Very nice job Ghound !
I like your window vents !
Thumbs Up Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #717317 12th Jul 2018 3:25pm
excossack
For my Defender, I posted off a transfer case and centre ATB to get made up into a complete TC to replace the Disco one in the 110 in preparation to return back to standard Defender TC 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #717372 12th Jul 2018 7:53pm
L110CDL
shaggydog wrote:
Oh yes still lurking Thumbs Up
Still having some difficulties but I'm hoping things will fall into place soon.
As for the doors I'm not sure the Link worked Ian but I think I know the stuff you mean. Just need some time to do it!
Land Rover/Spanner therapy sessions should be available on the NHS Laughing
Good that your still lurking and hoping all will be ok for you Thumbs Up Clayton.
Keeper.
Post #717400 12th Jul 2018 8:56pm
Went to D44 for a Service, brake fluid change, replacement sump, transferbox mounts, rear diff pinion oil seal.
Ended up needing new front brake pads, I thought they were okay but were a bit low.
Wish they would have told me before fitting though, cost that bit more than I planned for the brake pads.
There was traces of water in the rear axle oil so got it sorted out just in time!
Rear halfshafts and drive flanges are worn too.
Costs are getting hard to justify! Sad
I can't understand why I get next to no issues with the front but often something with the rear driveline.
Had the rear diff pinion oil seal replaced multiple times and the flange for Genuine as well, and after about 2 years it starts again.
At least most things are sorted now though, just goes to show how you can't always tell issues with your own vehicle until experienced people know what to look for.
Thumbs Up KEEP CALM AND Drill ON
Post #717421 12th Jul 2018 10:03pm
pux146
Added some Mantec roof bars. 2007 2.4 90 fettled & remapped.
Post #717430 12th Jul 2018 10:44pm
