Page 827 of 1383 <123 ... 826827828 ... 138113821383>
Vitesse
Started the headlamp wiring upgrade. Going for a custom wiring plan in order to incorporate the relays and also bespoke supply for driving lamps. All in one new wiring loom. Running new flexible conduit from the drivers seat box to the front o/s wing area. Also started to felt line the glove box after recently fitting the MSS kit Thumbs Up 2015 90 XS Santorini Black
Post #437208 12th Jul 2015 10:13am
90mojo
Finally got around to spraying the primed Wolf wheels I bought from Duckworths. Had been quoted £80 per wheel for 2k painting locally and took the advice on here not to get powder coated. So bought a gun for my compressor and used Paragon paints. Two coats of grey primer, then three coats of Limestone Cream.
First spray painting I've done for forty years....well pleased with the result.
Post #437238 12th Jul 2015 12:36pm
@ Ian Series 1..... They do look good! I had to go back into the garage later last night for another look Laughing
Post #437271 12th Jul 2015 6:43pm
munch90
word of advice when painting wheels ( if you want it Whistle )
when paint has hardened off for a few days , lay the wheel flat on the floor/bench face up , get a small brush and brush some waxoyl in to the crack where the outer rim meets the centre part , use a hair dryer to melt wax into the crack and round the welds , this is the part that always rusts first as it very hard to get paint down in the crack without getting too much round the crack and running etc
Post #437279 12th Jul 2015 7:15pm
90mojo
Thanks munch90, good tip Thumbs Up advice always appreciated, although I worked hard at it I could see penetration to the bottom of the join was lightweight. Seem to remember someone on here (with modulars?) Running a clear silicone bead round?
Post #437284 12th Jul 2015 7:26pm
munch90
Personally i would wax rust proof , if there is a gap in the silicone it will hold water in there , or water get in from the back
Post #437285 12th Jul 2015 7:31pm
90mojo
ThAnks munch90, makes good sense Thumbs Up
Post #437289 12th Jul 2015 7:56pm
TomekW
Poland 2003 Defender 110 Td5 SW Bonatti Grey
why powder coating is not recommended?
Post #437328 12th Jul 2015 9:33pm
Tiger
New wiper wheel boxes and drive cable
Thumbs Up
Post #437501 13th Jul 2015 6:03pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Tidied up the bird nest in the battery box. Cool
before:
After:
Post #437704 14th Jul 2015 5:00pm
Krissvdh
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Santorini Black
Great idea! Where did you get the under cubby box? Is it waterproof?
Kris
Post #437870 14th Jul 2015 10:51pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
90 is all painted and finished now, all pic's can be seen on LZ forum in the defender section ( my newly painted 90 ) Thumbs Up Mr. Green Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #437920 15th Jul 2015 9:16am
mrd1990
Kris
It's the Nakatanenga under cubby box http://www.defender2.net/forum/topic17431.html
I bolted it to the panel underneath so water can only get in by wading to above seat box height.
Pics of underneath:
Post #438060 15th Jul 2015 6:01pm
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Fitted 2 new presents (from me to the Landy Wink ) - variable intermittent relay for the wipers, and guards for the rear lights...
I know they're probably 90% cosmetic, but I like them! :thumbsup:
Post #438459 16th Jul 2015 10:43pm
AndyTunn
What did I do? Nothing!
Why not? Because it rained... quite a lot actually...
Post #438695 18th Jul 2015 7:16am
