Home > Maintenance & Modifications > Drawer runners |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 560 |
RS Online stock the accuride runners which are about the best but not cheap!
You might be able to find a local stockist via Hafele the wholesalers for accuride. 900mm ones here, http://uk.rs-online.com/web/p/drawer-slides/3826928/ Whole range to view, http://www.accuridedrawerslides.co.uk 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
4th May 2013 9:00am |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 |
Accuride as already stated
Another place to buy them from: Components Direct |
4th May 2013 9:17am |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Thanks, I've seen the Accuride runners, great product, but my design needs 7 pairs, so was hoping for something less than £100/pair (considerably less..!).
At those prices, I need an alternative design... cheers simon |
4th May 2013 9:53am |
Wow 7 pairs, that's some drawer system!!!
Coud you just not use friction slides? 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
4th May 2013 10:22am |
Cracka Member Since: 08 Dec 2012 Location: New South Wales, Australia Posts: 129 |
Post up some pics if you don't mind when you do it. I'm toying with the idea myself. |
4th May 2013 10:29am |
I have considered it, but I want to be able to pull the drawers out and have them support themselves. If I rely on friction runners, I would only be able to pull them 1/2 way out, otherwise they'd fall out..! I've ended up with 7 drawers as I want to split the load area. 2 for waffle boards, 2 for ropes/towing/recovery gear, 1 for the high lift jack, 1 for food and 1 for cooker/worktop space. cheers simon |
4th May 2013 5:21pm |
Here is my initial rough sketch of what I want to achieve. I'm learning Google Sketchup so I can make a better set of drawings. However, if I cant find affordable drawer slides, Ill need to find another approach. Click image to enlarge Any comments/ideas welcome. cheers simon |
4th May 2013 5:25pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Due to them not having much weight you should get away with runners from your local B&Q t about £10 a pair (about 70-90cm)). Do you need the full meter, I have been looking for mine and the set I am now look at are 70cm long and will cost me 6 Euros each.... for a saving of £90 a pair I can live with them being 30cm short. The weight limit is only 60Kg for a pair, but with so many draws I am guessing you wont have that weight in yours.
Glyn |
4th May 2013 6:35pm |
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 255 |
Another vote for Accuride. I use a 1m set for an Engel slide.
Sketchup is a good tool too My Disco 'best bits' Defender 110 XS CSW 2013 |
4th May 2013 6:37pm |
Glyn, As you say, with so many drawers I don't need so much weight. I only need a metre for the waffle boards. If I could get 90cm I'd be happy. A trip to B&Q sounds a good idea... Cheers for the idea... Simon |
4th May 2013 6:46pm |
Do you really need a drawer for the waffles? Why not just a suitably sized slot? The other thing with waffles is that they're a pain to stow inside when they're full of mud. Darren
4th May 2013 6:54pm |
I was thinking of a slot, but as you say they can get full of mud. My idea was to create a tray, on rails, that they can sit in and I can remove if/when they get covered in mud. If it was just a slot, I think it would get full of mud that would be hard to clean. I don't want the waffle boards on the outside, and this was the only practical way I could get them inside. I don't envisage using them a lot, its just for emergencies. Cheers Simon |
4th May 2013 7:35pm |
How about a bag to put them in first? Darren
4th May 2013 7:48pm |
If the rails aren't an option a bag would be a great idea Cheers Simon |
4th May 2013 7:59pm |
