Home > Puma (Tdci) > ABS T/C lights on |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 |
I have fixed mine. Would you believe it if i said i tightened the terminals up on the battery William
6th May 2013 5:48pm |
skyeplumb Member Since: 22 Apr 2013 Location: Isle of Skye Posts: 134 |
That's great news William8 - i'll double check mine when I get the car back, my negative was loose when I first got it - so loose that it wouldn't turn over the morning after I brought it home! so I tightened it - I did check the positive, but the design of the conical terminals is not too clever - defiantly worth a double check. Cheers Clive Series IIa Lightweight - Long Gone Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
6th May 2013 8:33pm |
Yeah well i did an Ohm test of all the sensors, and prodded the plugs a little, still nothing and then i tightened the terminals and i sorted itself.
My positive to the battery was loose (its the one that attaches to the bottom of the bar on the side of the battery). I thought they were tight enough but tighter works. William |
6th May 2013 8:50pm |
The garage have just said that they have found a fault - it was a wire to a rear sensor that had been rubbing and bared the copper causing the fault (nothing new then), odd that it wasn't logging a fault code on the computer.
Anyway - off to pick it up in the morning, another 400 mile round trip, hopefully with a this time and not bathed in amber light! Just ordered a scan gauge so I can see whats going on Series IIa Lightweight - Long Gone Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
7th May 2013 4:22pm |
Result Darren
7th May 2013 5:16pm |
