Home > Tdi > On going fuel sender problem HELP!
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
Got a fuel gauge reading full all the time, I have replaced 3 fuel senders 2 britpart , last one bearmack, but all look the same, replaced fuel gauge, added extra earth on gauge, wiring seems fine.
Its on a 200 tdi 90 1992 , had motor since 1999 and has never a problem with this till the last 6 months and I really cannot work this out, read different things on forums .
Its three wired type black / cream / green , have moved in different positions as some forums say britpart wiring is different to land rover's , no baffel in the way of the sender arm.
HELP HELP 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #229109 20th Apr 2013 1:43pm
natyeo
Sender part number STC1138
Fuel gauge RTC3107 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #229111 20th Apr 2013 2:02pm
RobKeay
Friend of mine had same problem with his D2! Fuel gauge all over the place. He got an oem one fitted by the garage at around twice the cost. It's all good now.
I'd try duckworths or JL services at willenhall they will sort you out I
Use JL for most of my stuff.
Post #229140 20th Apr 2013 5:16pm
natyeo
Finally got round to double checking every thing again bearmach sender , no different, and after another two fuel gauges, the second one was the fix.
Well all I will say is just keep trying and you'll get there! 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #404603 4th Mar 2015 11:10pm
