Home > Td5 > Defender TD5 flat spot woes and power loss! Please help!!
Page 2 of 2 <12
robk
Netherlands 2002 Defender 110 Td5 SW Epsom Green
It is regardless how far i press the throttle. Only after 15-20 secs of driving, the engine regains power.
Interesting to note:
- The rev's is not the problem when pushing the throttle, it is the power, the torque lacking.
- after a cold start, power and torque are suddenly back to normal after 15-20 sec
- when, after it regains power, i stop the engine and restart again, the engine needs again 5-10 seconds to regain power
- the rest of the day no problems anymore.
- disconnecting the MAF sensor does not have any effect
- When releasing the clutch the engine stalls easily.
I just discovered that the turbo's wast gate is stuck. At least I couldn't really shift it (yet) with a pair of pliers. So, will be my next item I will focus on.
KR
Rob
Post #487223 31st Dec 2015 11:27am
robk
An update:
I think the waste gate wasn't sticky after all, you just need a bit of force to shift it.
And the problem still remains. back to square 1. Big Cry
KR
Rob
Post #487473 1st Jan 2016 10:33am
miker
Mine has a similar problem. When it runs good, its great. When it doesn't there's no boost until much higher Revs. I've now Changed the maf, injector loom and fpr (because it was pouring out fuel!) And it still seems to be an issue. I need to re clean the ECU plug and drive it for a while before I can say for sure though.
Post #487485 1st Jan 2016 11:35am
ibexman
Could be a fuel pump issue. Have you changed filter
Post #487487 1st Jan 2016 11:59am
kevin1
England 1999 Defender 90 Td5 SW Rutland Red
had similar issue with mine pull away no power wait then away you go.after buying hawkeye found it was the map sensor the temp part was reading fine then no power the temp jumped to 136 degrees after 15-20 seconds dropped back to normal and power back to normal not a problem since map sensorchanged
Post #487701 2nd Jan 2016 8:13am
miker
I have cleaned the map sensor recently as well, could still be faulty though. I had a look through the records that came with the car, not sure when it was last serviced! Next stop, full oil and filters change!
Post #487739 2nd Jan 2016 11:35am
Fatboy Slim
Wales
Wiring to the airflow meter is knackered I expect. Check it especially where it runs round the front of the head. Tends to go a bit crispy there and starts rubbing through.
Post #488250 3rd Jan 2016 6:53pm
Page 2 of 2 <12
