Home > For Sale & Wanted > headlight leveler |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 559 |
You're easiest option might be to buy the complete wing looms with the plugs on.
They do occasionally pop up on eBay but I rang around the breakers and found some, cost £40 for the pair. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
4th Apr 2013 7:16am |
Is it not the same type of plug as used on stop/tail lights? If so, then they're available on eBay for a a couple of pounds. Can't search for a link from work but ISTR Bolt on Bits sell them. Darren
4th Apr 2013 9:23am |
Hassle Member Since: 21 Feb 2013 Location: Lincolnshire Posts: 6 |
40 pound for the plugs did you get LED main lights thrown in?
Not the same as red stop / tail Thank you for suggestions though. Easiest way is thin connectors with insulation and fill with black mastic, in fact could do a trailing lead then with a proper waterproof connector |
4th Apr 2013 9:55am |
£40 was for both sides complete looms!!
But yes pretty sure you could just use spade connectors and seal them. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
4th Apr 2013 10:07am |
Oh that's not so bad I guess
4th Apr 2013 10:12am |
