Home > For Sale & Wanted > headlight leveler
Hassle
1998 Defender 90 300 Tdi HT Cairns Blue
headlight leveler
After two working 3 pin plugs that fit the wipac headlight leveller motor from a td5 please, thank you
Post #224430 3rd Apr 2013 8:30pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
You're easiest option might be to buy the complete wing looms with the plugs on.
They do occasionally pop up on eBay but I rang around the breakers and found some, cost £40 for the pair. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #224478 4th Apr 2013 7:16am
Is it not the same type of plug as used on stop/tail lights? If so, then they're available on eBay for a a couple of pounds. Can't search for a link from work but ISTR Bolt on Bits sell them. Darren
Post #224502 4th Apr 2013 9:23am
Hassle
40 pound for the plugs Shocked did you get LED main lights thrown in?
Not the same as red stop / tail Big Cry
Thank you for suggestions though.
Easiest way is thin connectors with insulation and fill with black mastic, in fact could do a trailing lead then with a proper waterproof connector
Post #224513 4th Apr 2013 9:55am
db950
£40 was for both sides complete looms!!
But yes pretty sure you could just use spade connectors and seal them. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #224517 4th Apr 2013 10:07am
Hassle
Oh that's not so bad I guess
Post #224519 4th Apr 2013 10:12am
