Home > Technical > egr and barking up the wrong tree |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6308 |
I might just ask Ian but sounds like I might be wasting my time.....
I have to say the noise it far less of a concern these days but the lack of up get up and go in 1st gear compared to other times I just can't get my head round |
11th Mar 2013 8:32am |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
11th Mar 2013 8:34am |
11th Mar 2013 8:43am |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
Wayne,
We did the dynamic test a while ago - and it passed, but not a problem to run it again. To see if the EGR is suffering leak past, you could remove the hose from the inlet manifold (the stainless steel bit that bolts to the inlet manifold), and have a look how sooted up it is... If the EGR is leaking then the soot build up will be substantial. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
11th Mar 2013 9:06am |
firstly thanks for the response Ian.
so just to get this right.... disconnet the stainless steel pipe section with the egr sensor in it that sits between the plastic inlet manifold and inter-cooler rubber pipe? |
11th Mar 2013 9:26am |
Sorry... Yes... but just remove the rubber/silicon pipe from the intercooler where it goes into the stainless steel inlet. Shine a torch up your orrifice and have a look for sooty despoists (or excessive soot build up). Also, have you tried running some two stroke oil with the fuel? Especially as you run on that funny stuff Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 Last edited by Porny on 11th Mar 2013 9:55am. Edited 1 time in total |
11th Mar 2013 9:53am |
Tbh I thought you would have |
11th Mar 2013 9:55am |
Ian,
I've not dared using that funny stuff (not on the defender at least - the wifes 1.9 tdi golf on the other hand been running on stuff for the last 4 years) since I first met you - didn't want the defender going in for warranty work with a tank of funny fuel if something went wrong. been using the 2 stroke and its as if I get a slug of 2so and everything is smooth and nice and then the next thing it feels like a big slug of fuel/water and things are rough? I'm gonna start draining the fuel bowl off on a very regular basis see it that does anything.? gonna go check my phone now as I've got a photo somewhere of the egr sensor with soot on it but not sure how good the photo is and where you draw the line between substantia soot build up and normal.....I've since cleaned the egr sensor. found it....not sure if its much use tho..... Click image to enlarge |
11th Mar 2013 10:09am |
guys you're scareing me now..........
I'd expected someone to come back and say 'that looks normal'. |
11th Mar 2013 11:18am |
Thats' pretty gunked up...
I've be inclined to clean the MAP at least - or replace. Unfortunately, with your 'miss daisy' driving style, your EGR will be active nearly all of the time. Only closes fully at full throttle (as well as at different temps)... You could blank or remove the EGR - but this also needs to be done in the software, as it a major change to the air path calculations. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
11th Mar 2013 1:09pm |
thanks Ian.
I 'll perhap look at replacing.....price ayone? |
11th Mar 2013 1:11pm |
Part Number is LR022164 £113.62 - MAP sensor
Is yours still as per picture? As that is pretty gunked up. I'd be inclined to clean it first with brake cleaner or similar (carefully). Being gunked up will affect quite a few part of the engine calibration (pressure and temp). Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
11th Mar 2013 1:20pm |
can't recall how well it cleaned up. I'll have to have a look.
with it being gunked up is there likely to be a problem (other than my driving style) - is another trip to the dealers req'd ? At £113 - I'm inclined to think .......WARRANTY ! what they gonna brake this time aha - words of wisdom from MOG - knock current dealers on the head and go find somewhere else.....GS, coventry. I see a trip to halfords for some egr, brake cleaner or similar on the cards for tonight. thank you. |
11th Mar 2013 2:02pm |
having just pulled myself up off the floor
how comes the MAP sensor is £113 and the MAF sensor is like £20 - or have I got that wrong ? me thinks I might be on the road to recovery.......could this MAP sensor (along with gear box, ecu, input shaft etc) be the problem I've have all along? .......It can't be cos it must have been clean originally? |
11th Mar 2013 2:12pm |
