Home > Technical > egr and barking up the wrong tree
Page 2 of 2 <12
Caterham
I might just ask Ian but sounds like I might be wasting my time.....
I have to say the noise it far less of a concern these days but the lack of up get up and go in 1st gear compared to other times I just can't get my head round
Confused
Post #217960 11th Mar 2013 8:32am
bell-auto-services
Thumbs Up
Post #217961 11th Mar 2013 8:34am
Caterham
Very Happy
Thumbs Up
Post #217962 11th Mar 2013 8:43am
Porny
Site Sponsor
Wayne,
We did the dynamic test a while ago - and it passed, but not a problem to run it again.
To see if the EGR is suffering leak past, you could remove the hose from the inlet manifold (the stainless steel bit that bolts to the inlet manifold), and have a look how sooted up it is... If the EGR is leaking then the soot build up will be substantial.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #217965 11th Mar 2013 9:06am
Caterham
firstly thanks for the response Ian.
so just to get this right....
disconnet the stainless steel pipe section with the egr sensor in it that sits between the plastic inlet manifold and inter-cooler rubber pipe?
Post #217966 11th Mar 2013 9:26am
Porny
Site Sponsor
Sorry... Yes... but just remove the rubber/silicon pipe from the intercooler where it goes into the stainless steel inlet. Shine a torch up your orrifice and have a look for sooty despoists (or excessive soot build up).
Also, have you tried running some two stroke oil with the fuel? Especially as you run on that funny stuff Laughing
Ian IRB
Post #217970 11th Mar 2013 9:53am
bell-auto-services
Porny wrote:
Wayne,
Ian
Tbh I thought you would have Thumbs Up
Post #217972 11th Mar 2013 9:55am
Caterham
Ian,
I've not dared using that funny stuff (not on the defender at least - the wifes 1.9 tdi golf on the other hand been running on stuff for the last 4 years) since I first met you - didn't want the defender going in for warranty work with a tank of funny fuel if something went wrong.
been using the 2 stroke and its as if I get a slug of 2so and everything is smooth and nice and then the next thing it feels like a big slug of fuel/water and things are rough?
I'm gonna start draining the fuel bowl off on a very regular basis see it that does anything.?
gonna go check my phone now as I've got a photo somewhere of the egr sensor with soot on it but not sure how good the photo is and where you draw the line between substantia soot build up and normal.....I've since cleaned the egr sensor.
found it....not sure if its much use tho.....
Post #217973 11th Mar 2013 10:09am
Caterham
guys you're scareing me now.......... Shocked
I'd expected someone to come back and say 'that looks normal'.
Question
Post #217984 11th Mar 2013 11:18am
Porny
Site Sponsor
Thats' pretty gunked up...
I've be inclined to clean the MAP at least - or replace.
Unfortunately, with your 'miss daisy' driving style, your EGR will be active nearly all of the time. Only closes fully at full throttle (as well as at different temps)...
You could blank or remove the EGR - but this also needs to be done in the software, as it a major change to the air path calculations.
Ian IRB
Post #218017 11th Mar 2013 1:09pm
Caterham
thanks Ian.
I 'll perhap look at replacing.....price ayone?
Post #218018 11th Mar 2013 1:11pm
Porny
Site Sponsor
Part Number is LR022164 £113.62 - MAP sensor
Is yours still as per picture? As that is pretty gunked up. I'd be inclined to clean it first with brake cleaner or similar (carefully). Being gunked up will affect quite a few part of the engine calibration (pressure and temp).
Ian IRB
Post #218020 11th Mar 2013 1:20pm
Caterham
can't recall how well it cleaned up. I'll have to have a look.
with it being gunked up is there likely to be a problem (other than my driving style) - is another trip to the dealers req'd ?
At £113 Shocked - I'm inclined to think .......WARRANTY !
what they gonna brake this time Big Cry
aha - words of wisdom from MOG - knock current dealers on the head and go find somewhere else.....GS, coventry.
I see a trip to halfords for some egr, brake cleaner or similar on the cards for tonight.
thank you.
Post #218032 11th Mar 2013 2:02pm
Caterham
having just pulled myself up off the floor
Thud
how comes the MAP sensor is £113 and the MAF sensor is like £20 - or have I got that wrong ?
me thinks I might be on the road to recovery.......could this MAP sensor (along with gear box, ecu, input shaft etc) be the problem I've have all along?
.......It can't be cos it must have been clean originally? Confused
Post #218034 11th Mar 2013 2:12pm
Page 2 of 2 <12
