Home > Maintenance & Modifications > I want my 110 to be level and it's not..
ajctraveler
United States 2011 Defender 110 Puma 2.4 USW Orkney Grey
So here is my 110 when I first bought it, stock everything and it's pretty level front/back, if anything the back is slightly higher:
Since then I got OME springs, front and back and obviously a bunch of other stuff, but now the rear is sitting noticeably lower than the front:
I know there is obviously more weight in the back now, but I still don't think the springs should be effected so much and I'd really be happier if it were all level. Also these shots aren't even with a full tank.
Any advice or insight? My Travel Page
Post #214438 26th Feb 2013 2:19pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Come back and get a 3.2 put in to weigh it down at the front more Thumbs Up . Maybe look at the load levels of various springs out there and look for the stiffest 'mothers' you can find. If not there are custom fabrication companies out there that can make custom springs that will be able to provide springs to the load requirement you would require. ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #214441 26th Feb 2013 2:27pm
Luismi
Spain 2004 Defender 110 Td5 SW Alpine White
as Lishlandy say custom is the way to go
every car is diferent diferent equipment inside and maybe the most important diferent driver and we all tend to buy standard heavy duty of super heavy duty or watever.
weight your car per tyre as you usually travel with it and choose the right spring for it.
The typical seem to be go to a HD springs, however, doing that you are loosing the most important thing suspension overall in a expedition car as yours, and even more in a defender as you will experineced in yours travels.
Post #214448 26th Feb 2013 2:48pm
ibexman
Air lift helpers or inner 130 springs
Post #214460 26th Feb 2013 3:30pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Hi Tony
Can you please measure all four corners between top and lower spring mounts to see what difference there is front to rear. Going by pics it looks like it will be at least 1"
Assuming you are happy with existing springs you have two choices. OME spring packers, part no. For 110 rear is OMELRCP3, or springs spacers.
OME Spring packers are basically steel rings 8mm thick designed for adjusting height. You can place on bottom or top of spring or both to give 8mm or 16mm increase. OME advise one on bottom. At a push you could fit two on top and one on bottom to give 24mm, but to be safe you should be using spring retainers.
Spring spacers bolt to bottom spring mount and raise the mount by either 1, 1.5 or 2 inches. You can buy these or get them made locally. They tend to be either welded steel or billet aluminium.
By raising height you are reducing length of travel, so shock won't have as much travel before they meet limit and you are also changing propshaft angle. For overland use you really want to avoid going above a 1" lift over stock to minimise any issues like increased wear etc. Having said that, if extra weight is bringing rear down below stock height you should be ok. just mentioing so that you take this into account when you raise it.
Steve
Post #214461 26th Feb 2013 3:32pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
SteveG wrote:
Hi Tony
Steve
I did exactly that, 1" spacers under the spring seat, worked a treat, rear end of mine looks level now no matter what the load in the back Thumbs Up Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #214574 26th Feb 2013 9:03pm
landy andy
As above, if you like the ride, fit spacers. Don't just fit heavier duty spring as it will give you a hard ride. Gwyn Lewis does a few different types, and ones as small as 6mm so you can fine tune your setup.
Andy
Post #214586 26th Feb 2013 9:17pm
LR90XS2011
alternatively stick something heavy out front like a big fat winch, ps it looks great DEFENDER 90 TDCI XS,
Post #214592 26th Feb 2013 9:22pm
VeeTee
Netherlands
After I upgraded my old springs and dampers with new HD springs and Koni Heavy Tracks (+ 1"), I also needed spacers on the rear springs to get it level. Sits perfectly level now and ride is fine. Cheers, Vincent
MySite
Post #214605 26th Feb 2013 9:36pm
ajctraveler
SteveG wrote:
Hi Tony
Steve
Exactly what I was looking for, good man!
I'd be happy with another inch in the rear, so I'm going to try the single 8mm spacer. Seems a good balance taking everything into consideration.
Cheers My Travel Page
Post #214678 27th Feb 2013 3:42am
Glynparry25
Shocked Shocked .....No sexual innuendos there!!
Just out of intrest- what springs and shocks are you running (Part numbers)- I am still 50:50 between OME or airbags. I will be doing a whole load of overland soon and would like my rear to sit nice and high- helps keep the departure angle.
Glyn Dog Sheep
Post #214687 27th Feb 2013 7:39am
slap a winch on the front, that will balance it out Thumbs Up
Post #214689 27th Feb 2013 8:05am
ajctraveler
FML
I ended up ordering new OME HD springs and now I fixed my front/back lean but ended up with a left/right lean! Mad
Seems they aren't handed, which is what I originally thought was the issue, but my car is leaning left Sad I may try swapping the springs from side to side and see what happens or maybe I'm going to need a single spacer after all Crying or Very sad
Already got one..
 My Travel Page
Post #217402 9th Mar 2013 11:31am
taffrican
Don't fret too much Tony, you live and learn Thumbs Up Optimists say the glass is half full..
Post #217475 9th Mar 2013 6:18pm
keith
The rear is 1 inch higher than front . Iv always gone for 2 inch spacer on front and 1 inch on rear , this makes it level and gives a little more overall height , I change the shocks for +2 gas all round . No need to alter props or other mechanics .
Post #217488 9th Mar 2013 6:45pm
