Home > Maintenance & Modifications > muffler removing on the 110 puma engine |
expedition Member Since: 11 Sep 2009 Location: Vercelli-ITALY Posts: 75 |
For the benefit of the holders of Def> 2007 Ford engine, add the impressions gained from the removal of central muffler:
- A slight increase in torque at low revs, though noticeable, such as exit from the roundabout at third you feel a little less than that effect of vibration due to a poor copy. - A slight increase in diamond output from the tube end, especially at the very least, personally I do not mind, we say that makes a noise more "masculine", and a slight whistle of the turbo, before the change in dry marcia.Niente issue of striking, and nothing in comparison to a Td5 adopting the same treatment (unfortunately .. ) I note that my 110 has already undergone the change of the sensor clutch. To get a more favorable angle postriore I also eliminated the barrel end of the muffler, so being able to bend the curve and to shorten the tube, resolder the "lips" final. Vale 110 Td4 MY07 "E" Keswick Green |
28th Sep 2009 2:32pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
And mine Check the exhaust out. I have left the back box in place.
Click image to enlarge |
28th Sep 2009 2:41pm |
But you're already ahead!
Surely the next job will do the same thing! Vale 110 Td4 MY07 "E" Keswick Green |
28th Sep 2009 2:50pm |
Maverick Member Since: 08 Mar 2008 Location: Inverurie! Posts: 261 |
Doesn't it fail it's MOT like that?? Been considering this on the 300... Ben
Rebuilt 1996 black/white Defender 90 300 TDi |
28th Sep 2009 6:31pm |
29th Sep 2009 11:16am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8150 |
MOT is only a noise requirement, something like it doesnt make excessive noise or similar. my 90 tgv has no silencers and passes no problems. Cheers
29th Sep 2009 5:54pm |
Cedwat Member Since: 18 Jan 2010 Location: North Posts: 22 |
Hi,
I have a 110 puma too and am tempted to change the exhaust too. I think I have to keep the catalyser system as I may not pass our "contrôle technique" here in France! I have seen that many company in the UK propose "performance exhaust" for the TD4 : TD5 alive, JE, twisted, etc all have their "system". What is not clear to me is the difference between them. To be direct : it is just a tube, isn't it? Or is there secret science here? |
18th Jan 2010 5:41pm |
They are all just pipes
18th Jan 2010 6:26pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
i have a full stainless steel system from janspeed on mine side exit aswell with only a resinator sounds the nuts #
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
18th Jan 2010 7:11pm |
Mad Cow Member Since: 27 Oct 2009 Location: Hertfordshire Posts: 292 |
Yes this would fail the MOT, not on the noise but because the exhaust must extend clear of the bodywork/chassis. The back box on my V8 Disco was missing when I bought it.... made a luvvverly noise but not paticularly loud. However i had to add an extension to make it stick out the back to pass the MOT MAD COW 2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport Project90 |
30th Jan 2010 5:54pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2649 |
Andrew, did you leave the Cat in place or did you remove that as well? |
1st Jun 2010 7:58am |
Removed the cat. Got the de-cat pipe from Pete Bell 130's have feeling's as well you know
1st Jun 2010 8:09pm |
