Home > Maintenance & Modifications > muffler removing on the 110 puma engine
expedition
Italy 2007 Defender 110 Puma 2.4 SW Keswick Green
For the benefit of the holders of Def> 2007 Ford engine, add the impressions gained from the removal of central muffler:
- A slight increase in torque at low revs, though noticeable, such as exit from the roundabout at third you feel a little less than that effect of vibration due to a poor copy.
- A slight increase in diamond output from the tube end, especially at the very least, personally I do not mind, we say that makes a noise more "masculine", and a slight whistle of the turbo, before the change in dry marcia.Niente issue of striking, and nothing in comparison to a Td5 adopting the same treatment (unfortunately .. Laughing )
I note that my 110 has already undergone the change of the sensor clutch.
To get a more favorable angle postriore I also eliminated the barrel end of the muffler, so being able to bend the curve and to shorten the tube, resolder the "lips" final.
 Vale
110 Td4 MY07 "E" Keswick Green
Post #15975 28th Sep 2009 2:32pm
AndrewS
And mine Thumbs Up Check the exhaust out. I have left the back box in place.
Post #15976 28th Sep 2009 2:41pm
expedition
But you're already ahead! Thumbs Up
Surely the next job will do the same thing! Very Happy Vale
Post #15977 28th Sep 2009 2:50pm
scatt
England 2008 Defender 110 Puma 2.4 DCPU Alpine White
Re: muffler removing on the 110 puma engine
Have you removed the rear silencer aswell???
Post #15981 28th Sep 2009 5:47pm
Maverick
Scotland 1996 Defender 90 300 Tdi CSW Alpine White
Doesn't it fail it's MOT like that?? Been considering this on the 300... Ben
Rebuilt 1996 black/white Defender 90 300 TDi
Post #15983 28th Sep 2009 6:31pm
expedition
Thumbs Up Vale
Post #16005 29th Sep 2009 11:16am
jst
MOT is only a noise requirement, something like it doesnt make excessive noise or similar. my 90 tgv has no silencers and passes no problems. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #16017 29th Sep 2009 5:54pm
Cedwat
France 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Hi,
I have a 110 puma too and am tempted to change the exhaust too. I think I have to keep the catalyser system as I may not pass our "contrôle technique" here in France!
I have seen that many company in the UK propose "performance exhaust" for the TD4 : TD5 alive, JE, twisted, etc all have their "system".
What is not clear to me is the difference between them. To be direct : it is just a tube, isn't it? Or is there secret science here?
Post #22379 18th Jan 2010 5:41pm
AndrewS
They are all just pipes Thumbs Up
Post #22382 18th Jan 2010 6:26pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
i have a full stainless steel system from janspeed on mine side exit aswell with only a resinator sounds the nuts #
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #22388 18th Jan 2010 7:11pm
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
Yes this would fail the MOT, not on the noise but because the exhaust must extend clear of the bodywork/chassis.
The back box on my V8 Disco was missing when I bought it.... made a luvvverly noise but not paticularly loud. However i had to add an extension to make it stick out the back to pass the MOT MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #23248 30th Jan 2010 5:54pm
Naks
Andrew, did you leave the Cat in place or did you remove that as well?
Post #33377 1st Jun 2010 7:58am
AndrewS
Removed the cat. Got the de-cat pipe from Pete Bell Thumbs Up 130's have feeling's as well you know Smile
Post #33433 1st Jun 2010 8:09pm
