Home > Puma (Tdci) > Turbo 'whoosh'
Vera
2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Turbo 'whoosh'
Coming back up from Tenbury today I was aware of a change in volume of the turbo whoosh. If that makes sense. Basically up till today it was pretty much in the background, however today it's REALLY loud.. Any ideas? '09 SVX #200
'10 Morphy Richards.. I mean Prius
Post #211719 16th Feb 2013 7:26pm
K9F
Split/cracked pipe perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #211720 16th Feb 2013 7:28pm
Vera
maybe. Need to have a look when it's light tomorrow. Doesn't seem to be affecting the power tho. '09 SVX #200
Post #211723 16th Feb 2013 7:30pm
K9F
Vera they can be hard to spot especially if it leaks under pressure you may not see it. Get a really decent torch and a fine toothcomb.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #211733 16th Feb 2013 7:45pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Soapy water will help you find any leak.
Post #211743 16th Feb 2013 8:16pm
Vera
So... On the way back from Melton Mobrey, now getting a LOT of smoke fron the exhaust under any acceleration at all. Absolutely mo loss in performance, and other than the "whoosh", no odd/troubling noises..... Grrrrrrrr '09 SVX #200
Post #211934 17th Feb 2013 8:06pm
me@td5.org
Smoke but no loss in performance? Sounds like the turbo is still working and the MAF is registering a load of air and fuelling accordingly, but for some reason the air is not getting into he mix.
Post #211948 17th Feb 2013 8:45pm
Vera
Found it. Bolt coming through from the wing has punctured the hose to the inter cooler from the turbo. Has caused a 1" gash in the hose. At least now I know Smile) '09 SVX #200
Post #211967 17th Feb 2013 9:39pm
ZeDefender
Er...is this a LR bolt or one of yours Shocked ? Tell someone you love them today because life is short.
Post #211976 17th Feb 2013 10:11pm
Vera
Very LR. Will be getting dropped off at the dealership in the morning Very Happy '09 SVX #200
Post #211980 17th Feb 2013 10:15pm
ZeDefender
Please could you post a piccy or describe exactly where it is - should be added to the list of "LR screw-ups that need to be corrected before self-destruct" Rolling Eyes
Thumbs Up Tell someone you love them today because life is short.
Post #211988 17th Feb 2013 10:25pm
Vera
Thumbs Up
On that right now Smile. '09 SVX #200
Post #212004 17th Feb 2013 10:52pm
K9F
Vera wrote:
Found it. Smile)
Great news, well done. Thumbs Up Picture would be great.... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #212013 17th Feb 2013 11:02pm
Vera
Pretty awkward to take a photo of, but hopefully it gets the gist accross....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  '09 SVX #200
Post #212021 17th Feb 2013 11:19pm
ZeDefender
Thumbs Up brilliant - thanks.
I'll be checking mine a bit later Confused Tell someone you love them today because life is short.
Post #212041 18th Feb 2013 7:50am
