Home > Puma (Tdci) > Turbo 'whoosh' |
Split/cracked pipe perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
16th Feb 2013 6:28pm |
Vera Member Since: 08 Oct 2012 Location: Nuneaton Posts: 130 |
maybe. Need to have a look when it's light tomorrow. Doesn't seem to be affecting the power tho. '09 SVX #200 '10 Morphy Richards.. I mean Prius |
16th Feb 2013 6:30pm |
Vera they can be hard to spot especially if it leaks under pressure you may not see it. Get a really decent torch and a fine toothcomb.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
16th Feb 2013 6:45pm |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 |
Soapy water will help you find any leak.
16th Feb 2013 7:16pm |
So... On the way back from Melton Mobrey, now getting a LOT of smoke fron the exhaust under any acceleration at all. Absolutely mo loss in performance, and other than the "whoosh", no odd/troubling noises..... Grrrrrrrr '09 SVX #200
17th Feb 2013 7:06pm |
Smoke but no loss in performance? Sounds like the turbo is still working and the MAF is registering a load of air and fuelling accordingly, but for some reason the air is not getting into he mix.
17th Feb 2013 7:45pm |
Found it. Bolt coming through from the wing has punctured the hose to the inter cooler from the turbo. Has caused a 1" gash in the hose. At least now I know ) '09 SVX #200
17th Feb 2013 8:39pm |
Er...is this a LR bolt or one of yours ? Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
17th Feb 2013 9:11pm |
Very LR. Will be getting dropped off at the dealership in the morning '09 SVX #200 '10 Morphy Richards.. I mean Prius |
17th Feb 2013 9:15pm |
Please could you post a piccy or describe exactly where it is - should be added to the list of "LR screw-ups that need to be corrected before self-destruct"
Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
17th Feb 2013 9:25pm |
On that right now . '09 SVX #200 '10 Morphy Richards.. I mean Prius |
17th Feb 2013 9:52pm |
Great news, well done. Picture would be great.... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
17th Feb 2013 10:02pm |
Pretty awkward to take a photo of, but hopefully it gets the gist accross....
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated '09 SVX #200 '10 Morphy Richards.. I mean Prius |
17th Feb 2013 10:19pm |
brilliant - thanks.
I'll be checking mine a bit later Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
18th Feb 2013 6:50am |
