Home > Puma (Tdci) > What should i do?? |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
well i thought i had a good brake vac pump its lasted for 23k now its leaking and if you ask LR dealer or customer service theywill tell you that they have never heard of one failing , did have a chat with an ex LR mechanic and his advice was to have a pre warrenty inspection done on the understanding that you are going to sign up to an extended warrenty once its done don't sign and if you still want it extended there are scheme that you can get direct from third party, i'm told, and also try to find if there is a mechanic that drives a defender and see if he is a fan, it took me 1 1/2 years to find the one at my dealership but now he is finding bits that 12+ visits have miss'd.
20th Sep 2009 2:17pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
d/c/h
What bits have been found and missed. Cheers Karl NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
20th Sep 2009 9:08pm |
lornick Member Since: 02 Sep 2009 Location: Aberdeenshire Posts: 32 |
I'm in the same position, apart from mine has 18K on the clock.
I've decided to book it into a well respected local indpendant for it's 2 yr service (tomorrow) along with a thorough inspection of known weak points, gathered from this forum. Must say (fingers crossed/touch wood) that everything on my car appears to work as it should - I had it off-road for a session yesterday and based on the fact it's near standard, I was very pleased with how it performed. I'll let you know how I get on and what, if any suggestions are made. Cheers |
21st Sep 2009 11:11am |
fekete, i've writen this before i think, the main bits miss'd where when looking for a rattel from the rear end on rough ground nobody could find anything wrong until i found the defender fan who work'd there in one min he spotted that there was excess movement in the shock bushes, i mean visibale movement with just one hand, other stuff as well but bushes that he told me had been like that from the factory long live brian in chester
21st Sep 2009 9:23pm |
Sound bud, have read it before.
Been in today brake vacuum pump gone, Moor pipes need replacing and nuts loose on rocker cover, just got it back after 2 week was told vacuum pump had been changed but not, waiting for parts now NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
21st Sep 2009 9:31pm |
