![]() | Home > Puma (Tdci) > What should i do?? |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
well i thought i had a good brake vac pump its lasted for 23k now its leaking and if you ask LR dealer or customer service theywill tell you that they have never heard of one failing
d/c/h
What bits have been found and missed. Cheers Karl NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
lornick Member Since: 02 Sep 2009 Location: Aberdeenshire Posts: 32 ![]() ![]() ![]() |
I'm in the same position, apart from mine has 18K on the clock.
I've decided to book it into a well respected local indpendant for it's 2 yr service (tomorrow) along with a thorough inspection of known weak points, gathered from this forum. Must say (fingers crossed/touch wood) that everything on my car appears to work as it should - I had it off-road for a session yesterday and based on the fact it's near standard, I was very pleased with how it performed. I'll let you know how I get on and what, if any suggestions are made. Cheers |
fekete, i've writen this before i think, the main bits miss'd where when looking for a rattel from the rear end on rough ground nobody could find anything wrong until i found the defender fan who work'd there in one min he spotted that there was excess movement in the shock bushes, i mean visibale movement with just one hand, other stuff as well but bushes that he told me had been like that from the factory
Sound bud, have read it before.
Been in today brake vacuum pump gone, Moor pipes need replacing and nuts loose on rocker cover, just got it back after 2 week was told vacuum pump had been changed but not, waiting for parts now ![]() |
