Home > Puma (Tdci) > Alarm/interiors.
Page 2 of 2 <12
RED-DOT
Just opened door by fob and the interior lights both came ON and lockeD via fob and no alarm, re-locked it and no lights working and two beeps of the horn when locking. Interior roof lights don't work on manual or auto. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #206526 29th Jan 2013 1:15pm
Lorryman100
Have a look at fuse 30, 10amp under the steering column. Also check the grey plug connection in the 10AS for corrosion, and since you have it disconnected spray an electrical contact cleaner into the plug and 10AS ends before reconnecting. Below are the grey plug pin connections and the wiring diagrams for the interior lights and switch sensors. You can test the switch sensors are working by using a DMM, set in the 12v dc range and also coat the contacts in contact cleaner before reconnecting. Thumbs Up
Post #206556 29th Jan 2013 5:17pm
RED-DOT
No interior lights working at all both bulbs OK. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #206566 29th Jan 2013 5:51pm
RED-DOT
Scoured the internet but i have resorted to the famous Land Rover fault finder manual. http://1.2.3.11/bmi/pixweluv.com/files/fun...men_01.jpg 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #207016 31st Jan 2013 2:04am
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Red-Dot:
Your post at 2.04am!....so you can't sleep then?.....worrying about your Land Rover?!
Post #207052 31st Jan 2013 8:48am
RED-DOT
Land Rover ownership has its many benifits?? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #207061 31st Jan 2013 10:14am
RED-DOT
Done the AS10 plugs and still the same although the interior light flickered once. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #207084 31st Jan 2013 1:42pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Have you checked the bonnet switch Question Question Question LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #207108 31st Jan 2013 4:19pm
RED-DOT
Checked the continuity of the bonnet switch and it has continuity and is operating OK. Multiplug clean and dry. Alarm is now beeping twice every 15 minutes..... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #207120 31st Jan 2013 5:18pm
RED-DOT
This is driving me bonkers now... Alarm occasionaly sets without the horn but it also sometimes goes off full time. Interior lights sometimes flicker when the switch is in the ON position. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #209749 9th Feb 2013 8:33am
Liberace
Italy
Had this happen to my 2012 the first week of ownership. The dealer found the passanger door switch was not being depressed all the way when the door was shut. The switch itself was good just not enough displacement to the plunger when the door was closed. Symptoms included flickering dome light, especially on bumps. All he had to do was screw the adjuster out a few turns until there was a positive disconnect when the door was shut. Hope it is that simple for you,
ciao James
Post #210422 11th Feb 2013 2:46pm
RED-DOT
Had the interior door switches out and cleaned and they are working as they should be. Cant figure out why the interiors are not even working in the ON position.
No adjustment on my door switches but are all opening fully. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #210462 11th Feb 2013 5:25pm
mk1collector
Go back to basics. Is there a live and earth at the lights, if not is there a live and earth at the pin switches (check continuity between bulb and switch) if nothing at switch check live and earth at fuse then continuity between fuse and switch and so on and so on. Something is going to be amiss somewhere along the line.
Post #210494 11th Feb 2013 6:05pm
Page 2 of 2 <12
