![]() | Home > 130 > Demo 130 DCHCPU from Land Rover |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
nice one mate. is it a 3 month wait? and what spec? |
its also annoying they dont offer TC and ABS on the 130 either, that annoyed me when ordering.
any ideas why they dont? |
Standard length then, thanks for that ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404 ![]() ![]() ![]() |
something to do with the max weight and gross train weight when fully laden would put too much strain on the t/c system, and you can't specify one without the other. Mark S CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
Well that's bright seeing as it can be fitted to 44t lorries
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 ![]() ![]() ![]() |
Bali blue? |
but my 110 hd hicap which had a gross weight of 3500kg (same as the 130) had TC and ABS |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
This is a simple one. Its because the loom is too short ![]() |
No Firenze Red ![]() |
does this mean if you brought a 110 loom, extended it, would it all be there to "plug and play"....! or am i being optimistic! |
No idea TBH, you would have to fit the wheel speed sensors and the control unit etc etc. |
Landie Boy Member Since: 15 Jan 2011 Location: Essex Posts: 431 ![]() ![]() ![]() |
J-Lo getting old?
Jack |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Just re looking at this thread. My 130 has had 65psi in the rears from new. The rears are well worn in the centres and almost untouched on edges. Does anyone run a lower pressure? About 40 psi for light loads was my intention? 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
I run 44 rear and 35 front but I have non standard tyres.
If they are worn in the centre then yes they are over inflated for the task. 130's have feeling's as well you know ![]() |
