![]() | Home > Puma (Tdci) > Puma Intercooler Testing |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
Andrew from Allisport also told me this but have not heard it from anyone that has had the decat done to their vehicle. Mine is more a heat issue than performance so basically I want to get rid of the hot "ball" of metal..... ![]() 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
Zedefender, yep i know some advise against it.
But i do know of several not having the issue i have and as said i can see the vanes not being controlled on the scangage when it happens and i do have very dodgy connector and wiring at that place. FYI normally it steps down to keep around 1.4kg (kg it is i guess) and trigger fault code from 1.5 So i'm 99% sure its plug/wiring related. fingers crossed |
Was going through my emails now and the term that he used is surging of the turbo.
Don't know what that means. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
I'm also very interested as K9F kindly sold me his old down pipe from which I have duly hollowed out the cat.
My 110 still has 18 months of warranty left and my dealer (who is very helpful) pretended I never mentioned a de-cat ![]() But shout it at them in German because life is also terrifying and confusing... |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
I recently installed the Terrafirma decat pipe + central muffler removal pipe.
I was happy about the improvement but the noise was a little too loud for my taste. Also the odor of the exhaust gas was really noticeable. To avoid possible problem with police I choose to remove the decat pipe and rework the stock cat pipe by swapping the original ceramic cat with a high flow (close to 200 cell) sport cat. I'm very happy because the noise and gas odor are fairly close to the standard cat. This is the stock ceramic cat: ![]() Click image to enlarge And this is the high flow cat ![]() Click image to enlarge |
![]() Obvious question... where did you get it from? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
The stock cat exhaust was reworked here:
http://www.bartolimarmitte.com/ They basically cut the cat barrel, pull out the ceramic cat, install the new high flow one and weld the barrel in a very professional way, they look very nice. The new cat are designed to be more resistant and with the same life span of the stock unit. |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
I don't believe any of my customers have experienced surging as a result of fitting a decat. The surging will be down to the tuning anyway, not because of a less restricted gas flow through the exhaust. |
Interesting - have you or any of your customers noticed a change in exhaust smell after decat? Tell someone you love them today because life is short.
Most definitely, the smell of the exhaust gas without a cat is pretty damn pungent, so the cat does make that more palletable! ![]() |
Many thanks
Gary what does surging actually mean? Ie what happens.
Thx "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
Where the power delivery feels as though it is fluctuating as the car pulls through the rpm's. It should feel fairly linear and consistent, with smooth delivery throughout.
Ah ok thank you. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
