Home > Puma (Tdci) > Problem: I want to run WITHOUT EGR, solution.....
dgardel
Italy
............. I take off the EGR connector..........
my EML is ALWAY ON Whistle Whistle Whistle
but engine run so smooth and WITHOUT any smoke (my Puma is chipped).......
1 times a week I check with this http://www.auteltech.com/ms509.htm if it's all ok....
Post #15070 4th Sep 2009 9:38am
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Drill a 20mm hole in the centre of the blanking plate, this will reduce the amount of gas recirculated and still keep the amount of air pasing the mass air sensor happy! It took me and a few others many attempts to fine tune this so the light didn't come on.
Post #15077 4th Sep 2009 10:30am
dgardel
Italy
But do you feel the engine better? less smoke on EGR delay, or.....
Have you benefits with this solution?
Post #15078 4th Sep 2009 10:39am
mrwoo
Definately less smoke under full power, I to have a power upgrade (BAS)
Post #15096 4th Sep 2009 3:23pm
AndrewS
Like This Thumbs Up
Post #15097 4th Sep 2009 3:34pm
marcoegyptos
France
Hello Andrews,
Could you send me thr drawing with size and thickness to make this plate ?
It is steel or stainless steel ?
Post #15122 5th Sep 2009 6:52am
AndrewS
Pete from BAS is your man Thumbs Up
http://www.bellautoservices.co.uk/
Post #15168 7th Sep 2009 7:30am
marcoegyptos
France
Andrews,
I have contacted Peie but it canno't do anything for me. He don't want to sale because he said that there is a problem with this blanking plate and he need some time to solve the problem.
Any other solution to have the drawing?
Post #15229 8th Sep 2009 3:04pm
dgardel
Italy
marcoegyptos wrote:
Andrews,
If you send me your email, I scan the original gasket so you can do it yourself (with 0,5 - 0,8 mm thickness stainless steel sheet)
Post #15230 8th Sep 2009 3:13pm
marcoegyptos
France
dgardel,
I have send you my email address through your forum Inbox
Thanks in advance
Post #15233 8th Sep 2009 3:51pm
Caterham
does anyone know if the lastest fenders still have the same egr as the early ones.......and therefore the same potential problems?
Post #15307 10th Sep 2009 9:11am
marcoegyptos
France
dgardel,
Sorry to come back to the size of the blanking plate, but I didn't received your email
Thanks in davance
Post #15381 12th Sep 2009 12:33pm
bell-auto-services
sorry i could not help on this occasion, i only had a small batch of plates cut when i first gave them away on the forum and the drawing is with the profile cutters i dont have it.
I didnt get any more made untill more cars were out of warranty then we could disable the mil lamp also with mapping.
Pete
Post #15568 16th Sep 2009 8:06pm
dgardel
Italy
Download the sketch from HERE
Post #15570 16th Sep 2009 8:52pm
