Home > Puma (Tdci) > Problem: I want to run WITHOUT EGR, solution..... |
............. I take off the EGR connector..........
my EML is ALWAY ON but engine run so smooth and WITHOUT any smoke (my Puma is chipped)....... 1 times a week I check with this http://www.auteltech.com/ms509.htm if it's all ok.... |
4th Sep 2009 9:38am |
But do you feel the engine better? less smoke on EGR delay, or.....
Have you benefits with this solution? |
4th Sep 2009 10:39am |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 |
Definately less smoke under full power, I to have a power upgrade (BAS)
4th Sep 2009 3:23pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
Like This
4th Sep 2009 3:34pm |
marcoegyptos Member Since: 16 May 2009 Location: Vetraz-Monthoux Posts: 29 |
Hello Andrews,
Could you send me thr drawing with size and thickness to make this plate ? It is steel or stainless steel ? |
5th Sep 2009 6:52am |
Pete from BAS is your man
http://www.bellautoservices.co.uk/ |
7th Sep 2009 7:30am |
Andrews,
I have contacted Peie but it canno't do anything for me. He don't want to sale because he said that there is a problem with this blanking plate and he need some time to solve the problem. Any other solution to have the drawing? |
8th Sep 2009 3:04pm |
If you send me your email, I scan the original gasket so you can do it yourself (with 0,5 - 0,8 mm thickness stainless steel sheet) |
8th Sep 2009 3:13pm |
dgardel,
I have send you my email address through your forum Inbox Thanks in advance |
8th Sep 2009 3:51pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6300 |
does anyone know if the lastest fenders still have the same egr as the early ones.......and therefore the same potential problems?
10th Sep 2009 9:11am |
dgardel,
Sorry to come back to the size of the blanking plate, but I didn't received your email Thanks in davance |
12th Sep 2009 12:33pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
sorry i could not help on this occasion, i only had a small batch of plates cut when i first gave them away on the forum and the drawing is with the profile cutters i dont have it.
I didnt get any more made untill more cars were out of warranty then we could disable the mil lamp also with mapping. Pete |
16th Sep 2009 8:06pm |
Download the sketch from HERE
16th Sep 2009 8:52pm |
