Home > Maintenance & Modifications > Lowering my 90... Balancing needs with SWMBO requirements
Vera
2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Before anyone says it... yes, I've read through most of the posts on the subject, but none really answer my questions...
There are dozens of threads on the subject, but after reading most of them, I'm more confused than when I started!
I need to lower the SVX by between 1 & 2"...
SWMBO says I can't spend £1500 on a full suspension package, so for the moment if looks like I can only do the springs. So, can I just swap out the springs to give me the necessary height reduction (for the moment). And if so, which springs?
People talk about colours, progressive, H/D, standard etc etc etc... But with me being of simple mind, the simple answer is what I'm looking for. Pertinent fact is that the 90 is 99% road, with at most the odd rough farm track, so more road focused handling is important as is tha fact that my work car-park is a tight 2.05m.
My current thinking is get some springs first, then replace the anti-roll bars, then do the shocks. I want to keep the standard SVX wheels and tyres as I like them as they are. '09 SVX #200
'10 Morphy Richards.. I mean Prius
Post #200477 10th Jan 2013 11:10am
ZeDefender
Mine is lowered 4 cm just with the springs. I paid a lot to get them from a German company (loads of official papers you have to have here) but I'm sure there are cheaper options in the UK. The handling is great and the Defender looks quite "normal" Thumbs Up
If it's any use: http://www.matzker.de/Parts-Accessories/fu...:3484.html Tell someone you love them today because life is short.
Post #200508 10th Jan 2013 12:56pm
Vera
Exactly what I'm looking for.. now just need them to be a 10th of the cast Whistle '09 SVX #200
Post #200527 10th Jan 2013 2:07pm
ZeDefender
Just post in the wanted section for "Lowered springs" - it may get a bit more attention. The sponsors on here will certainly have some good ideas, especially tuners like Pete Bell (bell-auto-services), Gary at Alive, and Killer "how low can you go" 90 Laughing
Good luck Thumbs Up Tell someone you love them today because life is short.
Post #200530 10th Jan 2013 2:34pm
Killer90
Site Sponsor
Yer its just a straight swap i have them on mine as ZeDefender said How low can you go Whistle Rolling with laughter Rolling with laughter you can try and beat us its pretty low Wink re shocks im running genuine shocks at the moment but will later go to some bilsteins to match the springs. My springs were from extreme 4x4 Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #200570 10th Jan 2013 5:20pm
LR90XS2011
Try speaking to Porny, Ian from IRB he sells them or used to and is on this forum and he is not far from you either DEFENDER 90 TDCI XS,
Post #200571 10th Jan 2013 5:21pm
Yeah probably even lower with you in it. Whistle KEEP CALM AND Drill ON
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #200573 10th Jan 2013 5:24pm
td5 commercial
2014 Defender 90 Puma 2.2 HT Baltic Blue
I used to have my td5 lowered, it was so low I had to take the bumps stops out.....!
Post #200707 10th Jan 2013 10:13pm
