Home > Maintenance & Modifications > LED Interior Festune
Page 2 of 3 <123>
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi geobloke,
I've had those on my 90 for the past 5 months after having some poor results from some similar ones bought on eBay ( they lost LEDs over a few weeks. However the Amazon ones have stood the test of time and have not lost any LEDs. Very bright and very useful. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #200079 8th Jan 2013 8:11pm
geobloke
WelshGas wrote:
Hi geobloke,
Good to know Welshgas Smile
Post #200083 8th Jan 2013 8:19pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
If I fitted those aforementioned LEDS to my TD5, the soft start function wouldn't work, would it ?
Post #200094 8th Jan 2013 8:33pm
But they're white and not red. (Not that I'm saying their bad of course) Thumbs Up $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #200096 8th Jan 2013 8:35pm
geobloke
If you mean the gradual brightening and darkening then yes they do work, but are a bit steppy rather than a smooth act.
Post #200097 8th Jan 2013 8:37pm
appaloosadude
Ah, thats good. Thanks Thumbs Up
Post #200100 8th Jan 2013 8:38pm
Cool
38mm Do indeed fit but from fitting I think standard is 36mm bulbs. As the pins need slightly adjusting to take a 38mm.
0.1w draw 11w output on these. Standard bulbs are 10w draw and output. Is a bit darker being red but I prefer that than being lit up white like a football ground at night and it's much softer on the eyes. Also don't have the worry of leaving doors open and battery drain now. as basically as I do that a lot before I had them pretty much off all the time. Now with these they are on when the doors open. $W33T $0U7H3RN $UG4R
Post #202538 17th Jan 2013 10:53am
dgardel
Italy
mhmmmmm Steve........
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #202573 17th Jan 2013 2:06pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
How does that work then? If they were 0.1A consumption (assuming 0.1W is a typo), that would equate to 1.2W. If they were 11W that would be 0.9A?
Changing them for red ones must alter the laws of physics.
Pete
Post #202580 17th Jan 2013 2:23pm
dgardel - Wink
XS Pete - That was what I thought I read somewhere but I'm probably wrong then. (on hindsight can't remember where either) My mistake.
They are these:
http://www.autobulbsdirect.co.uk/272-LED-F...lours.html
Two reviews on them both 5star. $W33T $0U7H3RN $UG4R
Post #202618 17th Jan 2013 4:52pm
XS Pete
Ok I understand now. Their description says <1W which makes much more sense. To have been 11W they'd have needed a couple of 5W Crees in and then you'd have to drive about wearing welding goggles.
Pete
Post #202673 17th Jan 2013 6:36pm
"Designed with the latest LED technology the 272 will help to improve longer life up to 50,000 hours, improve durability and require less power consumption at less than 1W!! "
That was where I read it. Laughing $W33T $0U7H3RN $UG4R
Post #202682 17th Jan 2013 6:59pm
GUM97
Looking good Steve Thumbs Up What's it like in the dark ? An engine to TDi for!
Post #202688 17th Jan 2013 7:11pm
GUM - Cheers. Will try and take a photo tonight if I don't get frozen in the process. Shocked Being red it is obviously darker than standard but what I am impressed with with these is that they give a good light spread and not directional like some of the rubbish led versions. £5 each too so not cheap but good value for the quality. $W33T $0U7H3RN $UG4R
Post #202696 17th Jan 2013 7:34pm
Best photo I can come up with is this. Camera is only a phone one and seems to hate the light levels and colour so makes it look MUCH darker than what it really is. (you'll have to take my word for it)
Post #202706 17th Jan 2013 7:54pm
Page 2 of 3 <123>
