Home > Maintenance & Modifications > LED Interior Festune |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Hi geobloke,
I've had those on my 90 for the past 5 months after having some poor results from some similar ones bought on eBay ( they lost LEDs over a few weeks. However the Amazon ones have stood the test of time and have not lost any LEDs. Very bright and very useful. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
8th Jan 2013 8:11pm |
Good to know Welshgas |
8th Jan 2013 8:19pm |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 |
If I fitted those aforementioned LEDS to my TD5, the soft start function wouldn't work, would it ?
8th Jan 2013 8:33pm |
If you mean the gradual brightening and darkening then yes they do work, but are a bit steppy rather than a smooth act. |
8th Jan 2013 8:37pm |
Ah, thats good. Thanks
8th Jan 2013 8:38pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
Click image to enlarge Click image to enlarge 38mm Do indeed fit but from fitting I think standard is 36mm bulbs. As the pins need slightly adjusting to take a 38mm. 0.1w draw 11w output on these. Standard bulbs are 10w draw and output. Is a bit darker being red but I prefer that than being lit up white like a football ground at night and it's much softer on the eyes. Also don't have the worry of leaving doors open and battery drain now. as basically as I do that a lot before I had them pretty much off all the time. Now with these they are on when the doors open. $W33T $0U7H3RN $UG4R 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
17th Jan 2013 10:53am |
mhmmmmm Steve........
Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
17th Jan 2013 2:06pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
How does that work then? If they were 0.1A consumption (assuming 0.1W is a typo), that would equate to 1.2W. If they were 11W that would be 0.9A? Changing them for red ones must alter the laws of physics. Pete |
17th Jan 2013 2:23pm |
dgardel -
XS Pete - That was what I thought I read somewhere but I'm probably wrong then. (on hindsight can't remember where either) My mistake. They are these: http://www.autobulbsdirect.co.uk/272-LED-F...lours.html Two reviews on them both 5star. $W33T $0U7H3RN $UG4R 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
17th Jan 2013 4:52pm |
Ok I understand now. Their description says <1W which makes much more sense. To have been 11W they'd have needed a couple of 5W Crees in and then you'd have to drive about wearing welding goggles.
Pete |
17th Jan 2013 6:36pm |
"Designed with the latest LED technology the 272 will help to improve longer life up to 50,000 hours, improve durability and require less power consumption at less than 1W!! "
That was where I read it. $W33T $0U7H3RN $UG4R 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
17th Jan 2013 6:59pm |
Looking good Steve What's it like in the dark ? An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
17th Jan 2013 7:11pm |
GUM - Cheers. Will try and take a photo tonight if I don't get frozen in the process. Being red it is obviously darker than standard but what I am impressed with with these is that they give a good light spread and not directional like some of the rubbish led versions. £5 each too so not cheap but good value for the quality. $W33T $0U7H3RN $UG4R
17th Jan 2013 7:34pm |
Best photo I can come up with is this. Camera is only a phone one and seems to hate the light levels and colour so makes it look MUCH darker than what it really is. (you'll have to take my word for it)
Click image to enlarge $W33T $0U7H3RN $UG4R 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
17th Jan 2013 7:54pm |
