Home > Technical > Wanted to borrow: Steering wheel puller
Page 3 of 3 <123
mk1collector wrote:
Or pour boiling water on the nut the pull at 3 and 9 positions
ZeDefender wrote:
I have warmed my nuts up before twisting them in the past though...
I'm sure it would be warm if you did that. Shocked Rolling with laughter Shocked
Sorry had to be said. Whistle KEEP CALM AND Drill ON
Post #199417 6th Jan 2013 3:56pm
Tiger
Merlin wrote:
This is what I used:
http://www.ebay.co.uk/itm/Landrover-specia...1c2ef09e35
But, if you then fit a different wheel, it doesn't work!
Merlin
That's what I meant, gonna have to make one I think Sad
Post #199635 7th Jan 2013 9:37am
geobloke
Merlin
Do not fret it is really easy to make a steering wheel puller, took maybe 20 mins, I did it on Saturday, worked a treat.
Post #199678 7th Jan 2013 1:13pm
ZeDefender
Smart Thumbs Up Tell someone you love them today because life is short.
Post #199680 7th Jan 2013 1:20pm
geobloke
ZeDefender wrote:
Smart Thumbs Up
Thanks, the leather feels really good in your hands. I went for the same diameter as standard, which being more slimline means you can see more of the dash. The only little quirk is that the full beam to dipped beam lever is a bit of a stretch (finger tips) I will bend the arm a little later on today... Very Happy
Post #199681 7th Jan 2013 1:27pm
yorky
England 2007 Defender 90 Puma 2.4 SW Java Black
How did you get on with bending the stalks? I fitted a Momo wheel recently and I've developed the stretched finger technique to operate the stalks, not a major problem but if bending the stalks without causing an issue is easy then it's worth doing. Thumbs Up 90 XS
Volvo V70
Post #199981 8th Jan 2013 4:48pm
barbel jim
Really like the mota-lita wheel. The only bit I dont,t is the gap created by the need for a boss(on all aftermarket wheels). Like DieselJjims solution, just need a workshop and welder. RDX do a slimline boss, although this still looks big to me. Dose anyone know of real slimline boss, that looks more OEM ?
Post #199984 8th Jan 2013 4:57pm
Page 3 of 3 <123
