Home > In Car Electronics > My radio has become a free spirit.....
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
I should have had this looked at whilst still under warranty I guess, but the radio in my Puma constanly keeps reverting to a news channel from either Radio One or a CD - I thought it was because I had the 'traffic announcement' option selected, but now without that it still keeps changing channels?
Any ideas - apart from the obvious which is 'drop testing' it from a great height! Euro-Leafing to infinity and beyond.....
Post #197755 31st Dec 2012 12:50pm
Could be worth getting a can of spray contact cleaner, douse the buttons with it and repeatedy push them lots of times, see if it cleans them up... you may have a sticking button?
Post #197757 31st Dec 2012 12:54pm
GUM97
My dad had the same problem, and cured it by holding the traffic button down for a while, rather than just pressing it. The button was a bit tempremental Confused An engine to TDi for!
Post #197759 31st Dec 2012 12:56pm
Try disconnecting it completely and then re-connecting it up(after 20mins or so) so that you have to enter the security code in. This might re-start it and clear any errors messing it up. Failing that if you have traffic updates off I can't think of much you can do. Except for perhaps upgrading to an aftermarket unit.. If you wanted just CD and radio from one a good premium band head unit would only cost you around £50 - £70 and would be plug and play. Not sure what an OE LR radio would cost probably £100 + at least. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #197760 31st Dec 2012 12:56pm
VeeTee
Netherlands
On most models with RDS (Radio Data System) one can select a favorite PTY code (Program Type). May be you selected (by accident) the "News" PTY code ? Cheers, Vincent
MySite
Post #197764 31st Dec 2012 1:02pm
JWL
Instead of a total disconnect is there not a reset button, I only ever delve into the el-cheapo end of the market for ICE but there has allways been a reset button often just a small hole under a removable fascia into which I poke a cocktail stick(non conductive in case it's the wrong hole Whistle )
Post #197769 31st Dec 2012 1:08pm
That's true. Trouble is some do some don't. I can't remember if mine does or not. Whistle Saying that it's never played up to need it gods honest truth. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #197800 31st Dec 2012 2:29pm
jerseyman
Mine randomly changes channels, the only solution I have found so far is to switch it off
Post #197809 31st Dec 2012 2:48pm
Could well be due to poor reception. I find I don't use the radio much for that reason. Could do with a booster really but personally I don't feel it worth the effort. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #197822 31st Dec 2012 3:29pm
strang
Thanks for the suggestions - a good few ideas there... Euro-Leafing to infinity and beyond.....
Post #198210 1st Jan 2013 7:09pm
strang
Well it was the 'PTY' option, selected by holding the info button in for a while, and removed the same way. I read the instruction book, and all became clear...... Embarassed Euro-Leafing to infinity and beyond.....
Post #205202 25th Jan 2013 1:13pm
