Home > Maintenance & Modifications > Windscreen wiper washers
Page 2 of 2 <12
VeeTee
Netherlands
ZeDefender wrote:
Yep - saw those but they are so low down (if fitted as standard) - I guess other cars' wipers are set up differently. These are mine:
http://www.ebay.de/itm/271097631269?ssPage...1439.l2649
Thanks. Aber... Schade, Dieses Angebot wurde beendet.... Sad Cheers, Vincent
MySite
Post #194900 19th Dec 2012 1:15pm
ZeDefender
You can certainly do better - mine are okay but definitely NOT as impressive as the eBay pictures Laughing Tell someone you love them today because life is short.
Post #194908 19th Dec 2012 2:02pm
Tiger
Go to a scrap yard
Locate a Peugeot 405
Remove wipers and fit plastic squirt bits to Defender wiper arms.
Post #194911 19th Dec 2012 2:12pm
ZeDefender
Do they all have washers? No scrap yards around here - I'd have to be very specific what I asked for when I ordered it Sad
Do you happen to have a pic where they fit on yours? Is it in the middle of the blade?
Matt Tell someone you love them today because life is short.
Post #194915 19th Dec 2012 2:47pm
Tiger
Post #194919 19th Dec 2012 3:26pm
ZeDefender
Wow! So they stretch the full length of the wiper blade - huge Shocked
First time that's been mentioned and not at all obvious from Peugeot 405 spares sites.
No wonder I couldn't find them Rolling Eyes
Thanks - off to search further... Tell someone you love them today because life is short.
Post #194921 19th Dec 2012 3:38pm
ZeDefender
Just looked carefully (in the dark) and I see why it isn't essential to have full-length squirting:
The system I have squirts about 4-6" wide under the blade (so behind it on the upstroke) but as the blade returns back down (mine is LHD) you can see it spreading down along the blade so the whole screen is cleared Thumbs Up
(Camera is a bit low down - the wash is actually more in the line-of sight)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #194957 19th Dec 2012 6:04pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I've just done this mod, thanks to everyone for the pointers in this thread. It's been worth all the effort and was actually a fairly quick and easy job. I also found out it was a faulty no-return valve that was causing the lack of pressure.
I made a little video here of the finished project:
Since then I've cut ~2" off the end of the pipes so the water goes in the middle of the screen.
Post #393018 27th Jan 2015 3:20pm
ZeDefender
Thumbs Up Bow down
Never regretted doing mine, especially in this God-awful weather Rolling Eyes Tell someone you love them today because life is short.
Post #393053 27th Jan 2015 6:20pm
sat13
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
http://www.defender2.net/forum/topic34304.html
From a posting a few days ago, my mod to the screen wash.
Fletch.
Post #393282 28th Jan 2015 12:08pm
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
Just a thank you to ZeDefender and the forum ... Bow down
washer jet fractured (bird strike? froze solid & fractured here in Chur?) and instead of pulling dash apart....
simply pulled apart replacement in a vice (yep, real stiff) and tapped new jet back on the stub.
- fancier fixes can be done when I have a shed back in UK or Oz.
The compiled knowledge here, from main bearings to washer jets .. is more than handy .. Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #404159 3rd Mar 2015 5:09pm
x-isle
I totally forgot when I mentioned (possibly in another post) that I was going to do this and share the photos. I did it about 2 weeks ago. Made a very simple job of it.
I cut the bit sticking out off the original washer jet (with the front part removed) and then I used a rubber mallet to knock a 3mm T-piece (slightly trimmed to fit) then simply used some thick 3mm rubber pipe (which has an overall width of 7mm). This helps it stop freezing. I didn't use any non-return valves as I actually want the water to drain back slightly. After 2 subzero mornings, so far no frozen pipes.
The clips are simply edge clips that I put some self-amalgamating tape underneath to protect the paint and stop the gutter rusting.
Here is a video showing the water jets coming out.
 Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #404498 4th Mar 2015 5:25pm
Page 2 of 2 <12
