Home > Maintenance & Modifications > Windscreen wiper washers |
Thanks. Aber... Schade, Dieses Angebot wurde beendet.... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
19th Dec 2012 1:15pm |
You can certainly do better - mine are okay but definitely NOT as impressive as the eBay pictures Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
19th Dec 2012 2:02pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Go to a scrap yard
Locate a Peugeot 405 Remove wipers and fit plastic squirt bits to Defender wiper arms. |
19th Dec 2012 2:12pm |
Do they all have washers? No scrap yards around here - I'd have to be very specific what I asked for when I ordered it Do you happen to have a pic where they fit on yours? Is it in the middle of the blade? Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
19th Dec 2012 2:47pm |
19th Dec 2012 3:26pm |
Wow! So they stretch the full length of the wiper blade - huge
First time that's been mentioned and not at all obvious from Peugeot 405 spares sites. No wonder I couldn't find them Thanks - off to search further... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
19th Dec 2012 3:38pm |
Just looked carefully (in the dark) and I see why it isn't essential to have full-length squirting:
Click image to enlarge The system I have squirts about 4-6" wide under the blade (so behind it on the upstroke) but as the blade returns back down (mine is LHD) you can see it spreading down along the blade so the whole screen is cleared (Camera is a bit low down - the wash is actually more in the line-of sight) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
19th Dec 2012 6:04pm |
Never regretted doing mine, especially in this God-awful weather Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
27th Jan 2015 6:20pm |
sat13 Member Since: 06 Jun 2010 Location: Cheshire Posts: 70 |
http://www.defender2.net/forum/topic34304.html
From a posting a few days ago, my mod to the screen wash. Fletch. |
28th Jan 2015 12:08pm |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 223 |
Just a thank you to ZeDefender and the forum ...
washer jet fractured (bird strike? froze solid & fractured here in Chur?) and instead of pulling dash apart.... simply pulled apart replacement in a vice (yep, real stiff) and tapped new jet back on the stub. - fancier fixes can be done when I have a shed back in UK or Oz. The compiled knowledge here, from main bearings to washer jets .. is more than handy .. Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
3rd Mar 2015 5:09pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
I totally forgot when I mentioned (possibly in another post) that I was going to do this and share the photos. I did it about 2 weeks ago. Made a very simple job of it.
I cut the bit sticking out off the original washer jet (with the front part removed) and then I used a rubber mallet to knock a 3mm T-piece (slightly trimmed to fit) then simply used some thick 3mm rubber pipe (which has an overall width of 7mm). This helps it stop freezing. I didn't use any non-return valves as I actually want the water to drain back slightly. After 2 subzero mornings, so far no frozen pipes. The clips are simply edge clips that I put some self-amalgamating tape underneath to protect the paint and stop the gutter rusting. Click image to enlarge Click image to enlarge Click image to enlarge Here is a video showing the water jets coming out. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
4th Mar 2015 5:25pm |
