![]() | Home > Puma (Tdci) > Diff,Switch & step, fair play Main stealer |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
Thata a bit like asking about 'front bottom'! ![]() 2011MY 110 XS USW Black |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
prop to diff flange? Cheers
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1822 ![]() ![]() ![]() |
Rear drive flanges in the centre of the wheels
Keith |
T5bnc Member Since: 13 Sep 2012 Location: S.Wales Posts: 40 ![]() ![]() ![]() |
Typically I forgot to ask when I picked it up earlier! Although now the clock has stopped working I'm guessing they forgot to hook it up when refitting the dash? To that end is it just a case of whipping the three bolts off the console to get at it do you think?
Cheers Ben |
For the sake of completness took the Torx screws out and stereo popped the dash off, that was a moment of panic I know thought i broke it! and reconected the clock. job done! |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
I had a similar noise issue on my '09 Puma, had to take it to three different dealers to get it sorted. Not any one did all the work, but between the three of them they sorted it.
One of the causes was the rear drive flange... sadly can't remember what the issue was (think it was worn). |
