Home > Td5 > Does disconnecting the ECU give problems?
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I would like to put the ECU at a higher so dryer place.
Will disconecting the ECU from the cables give problems to the ECU or faultcodes?
Is there a procedure to follow?
Thanks Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #14387 18th Aug 2009 4:09pm
foz.in.oz
Australia 2004 Defender 110 Td5 SW Bonatti Grey
You should not have any issues as long as you disconnect the battery first and wait for about a minute before disconnecting the ECU. Mine has been in an out of the car half a dozen times now.
Don't forget to check your radio code before disconnecting! Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG
Post #14398 18th Aug 2009 9:12pm
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Re: Does disconnecting the ECU give problems?
Thanks
Are you going raise up to cubby box or roof height ?, I saw a thread somewhere for wiring extension for TD5
if thats useful
Post #14400 19th Aug 2009 12:20am
Glynparry25
I know Devon 4x4 do an extention: http://www.devon4x4.com/products_a/p1755c2...nsion.html
As above, all you need to do is disconect the battery for a little while first.
Glyn
Post #14409 19th Aug 2009 9:30am
roel
Thanks guys,
First I want to see how high I can get it in the Cubby box/ bulkhead direction.
I don't know yet how I will want to have my roof yet. It's now a sheep farmer's pick-up with the Ifor Williams canopy on the back. I kind off like that as you don't see them this way in The Netherlands.
On the otherside a hard top with windows is more practical but that is the standard here.
I would like to drive it as a softtop in the summer but not in the winter.
So I would like to have the ECU as high as possible but I don't know how high yet. Roel
Post #14426 19th Aug 2009 9:07pm
Tatt
South Africa 2002 Defender 110 Td5 HT Belize Green
Moving the ECU
Found this on the PPcages website - looks like they did a pretty good job when they moved the ecu:
http://www.ppcages.com/index.php?Rollcage=seatbrackets
Tom
Post #14493 21st Aug 2009 9:27pm
roel
That's were I wanted to mount it too. The 90's color is correct too. I just don't like the seat holders. Roel
Post #14506 22nd Aug 2009 11:23am
Tatt
The one advantage of mounting it there is that there is little chance of the oil seeping down the loom getting into the ecu - it will probably just leave a puddle on the seatbox instead!
I intend moving mine to the same spot when I finally get rid of the centre seat.
Tom
Post #14510 22nd Aug 2009 1:20pm
roel
You can fit it there with the standard wireloom, you just need to extent the cables to the transfer box for the High/low sensor and the difflock sensor.
That project is almost finished just need a new ECU as mine has had swimming lessons and clearly didn't make it. Roel
Post #15198 7th Sep 2009 7:26pm
jst
cubby box or similar height gets my vote, if its in the roof and you go over - its at lowest point then! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #18242 12th Nov 2009 5:56pm
